337 Flatheads
Discussion in 'The Hokey Ass Message Board' started by Vic, Jan 19, 2005.
  1. SAVAGE
    SAVAGE
    Alliance Vendor
    I have a 2x2 nicson intake for one hangin around. I might sell for the right price..
  2. ratfink8
    ratfink8
    i have a 337 sittin in my lincoln right now, i wanna pull it and put it in my 29 A, where can i get waterpumps for it?? or just parts in general
  3. hotrod1940
    hotrod1940
    Vic, I had a 337 in a 1946 Lincoln coupe in 1957. Replaced the v_12, but it still had the overdrive. It would really run in second gear overdrive and surprised a lot of people. Had an Isky 3/4 cam, headers, Mallory distributor, 4 barrel on a two barrel manifold, milled heads. I got walk off and leave a new 57 Ford, but I couldn't quite beat a Chevy v-8. Great fun and memories and that thing sounded cool.
  4. tjm73
    tjm73
    I've never seen a definitive answer to the "what transmissions will fit the 337?" question. Doe sthe big Flattie use the same bellhousing pattern as the regualr '49-'53 Flattie?
  5. Dale Fairfax
    Dale Fairfax
    ***uming you're talking about the stick, the Lincoln used the B-W T-85 three speed with the R-11 overdrive which I believe was the same as '60s Fords and Mercs. The bolt pattern is the same as the earlier (49-5?) Fords and Mercs.
  6. Dale Fairfax
    Dale Fairfax
    Water pumps are rebuildable. Most metro areas have someone that can do it but if you can't find anybody near you, try Skips Pumps in Punta Gorda, FL. Overhaul parts are available from Bob Selzam at "Half Ton Fun" in Jackson, NJ. No e-mail; just a phone: 732-928-9421.
  7. Dale Fairfax
    Dale Fairfax
    I've got about $2000 in a complete rebuild : new pistons (+.040), bearings, rings, cost of boring (and sleeving one cylinder), grinding the crank (.010,.010), and grind the valves. Fortunately I already had the Edmunds heads and 2 X 2 manifold from several years ago ($1200 at a swap meet in 1989). Sounds like a lot of money but I've already got a Chevy and a Flathead Merc-this gives me something different (very).
  8. Dick Dake
    Dick Dake
    How to Build Cl***ic Hot Rod V-8 Engines by George McNicholl ISBN-13-978-0-7603-2777-7.
    Has all the part numbers, suppliers, and does a Dyno test. 223 hp/ 373 ft-lbs sounds good to me. Austin sells a blower intake which would probably kick it to 275-300 hp. I am looking to do 3x2 with 2 piece Billet heads. Crower will do a cam and with enough cubic money, i believe you could bore and stroke one out to 374 with custom parts.
  9. Dick Dake
    Dick Dake
    If anyone wants to get rid of them let me know, heck, let Dale know. Don't s**** them. I'm sure we could save them.
  10. tjm73
    tjm73
    So if I am understanding things correctly......if I found a 337 with no trans and wanted to put a modern 5 speed behind it I could use the bellhousing from any regular '49-up Flattie with the 5 speed of my choice?
  11. Dale Fairfax
    Dale Fairfax
    If you find one with no transmission, you'd better hope it had been a stick version. The flywheel and bell housing are one of a kind. What I said was that the transmission that bolts to the '49 thru ---Ford (or the '51 thru --Merc) will bolt to a Lincoln bell housing. The Ford/Merc bells don't bolt to the Lincoln block. Of course,with enough resources (material and a machine shop), anything can be adapted to anything.
    quote=tjm73;2999084]So if I am understanding things correctly......if I found a 337 with no trans and wanted to put a modern 5 speed behind it I could use the bellhousing from any regular '49-up Flattie with the 5 speed of my choice?[/quote]
  12. tjm73
    tjm73
    Ahhhhh...that's the bit of information I've never been able to find. Bellhousing and flywheel different, but ****** interchanges. Check.
    Thank you very much. :D :cool:
  13. Ol Blue
    Ol Blue
    from In
    I saw this dressed out engine a couple of years ago, good lookin!
    Ol Blue
  14. Dick Dake
    Dick Dake
    Bentsens sells adapters for them. He actually likes the 200r4. The one I have has the Hydromatic behind it. I also wondered about the weight thing. Caddies are heavy yet good, Lincolns are heavy and bad. Must be a cult or something.
  15. Jive-Bomber
    Jive-Bomber
    MODERATOR
    WOW!!!
    Thats some ULTRA-RARE stuff on that motor-- So killer! Seems a shame to hide it under a hood!
  16. Dale Fairfax
    Dale Fairfax
    I think there was some sort of mystique built up around the Caddy 346. It was in production for a long time and, of course, was used to power tanks in WW II. However, it was NOT known for any ability to take abuse-Ak Miller related (in some book I can't lay my hands on right now) how he used to buy Caddy engines and install them in some old Ford he was street racing. He bought them from junk cars and several p***es at 4G returned them to the junk yard.
  17. chris51lincoon
    chris51lincoon
    from austin, tx
    i want it ..need it for my 51 lincoln
  18. edgeabilly
    edgeabilly
    Oh and let me know!!!
    :D
