34 chev Master and 57 Corvette
Discussion in 'The Hokey Ass Message Board' started by seb fontana, Jun 10, 2012.
  1. seb fontana
    seb fontana
    from ct
    A friend lost his repair plates so now needs to know where the vin#'s are supposed to be on the two cars..?
  2. Vette tag is on the steering column and the frame is stamped in 2 or 3 locations
    the '34 I can't help you
  3. MotorCityDeuce
    MotorCityDeuce
    57 Corvette VIN is stamped on the top of the frame, directly under the drivers seat. Virtually impossible to read with the body on the frame. VIN is also on an aluminum tag that is screwed on in the drivers side door jam. Tag on steering column started on '58 I believe.
  4. GregCT.
    GregCT.
    from CT.
    MotorCityDeuce is correct. We used to have to cut the floor between the seat track and door opening to show CT. DMV the VIN.
  5. OOOPS you are correct. I remember my 54 had the same tag location.
  6. NAPA 68
    NAPA 68
    You are correct.
    Tim
  7. Torkwrench
    Torkwrench
    The tag on a 34 Master is nailed to the wooden passenger side floorboard, just in front of the front seat and a few inches in from the rocker. Most of the time it disappeared when the wood rotted away.
  8. seb fontana
    seb fontana
    from ct
    Thanks guys..I'll relay the info tonight, much appreciated!!
  9. Duntov-097
    Duntov-097
    The tag was moved to the column in 1960, right around VIN #1500.
