does anyone know what rotors and bearings will work on 34 chevy spindles? I am also looking for an inexpensive four link set up for the rear. Planning on the underslung front. Suggestions?
I don't recall all the individual pieces to pull off the conversion but there are the folk at ECI that could probably answer your question. Checkout their ECI Disc Brake Conversion Kit
Try the Filling Station for their conversion kit #FS-715. <SMALL>DISC BRAKE CONVERSION KIT Basic Models w/ Straight Axle DOES NOT WORK WITH 1933-36 STANDARD MODELS. Use with your existing spindles. Top quality US made bolt-on assembly. Includes caliper mounting brackets - attaching hardware to spindle - bearing adaptors ( which use modern tapered roller bearings) and instructions using YOUR late model calipers - rotors - pads - seals and bearings (1972-77 Camaro or equivalent). http://www.fillingstation.com/</SMALL>
