i am putting a 350/350 in my 34 Master. I would like anybody with one of these to tell me if they had to do anything to the X-member drive line tube to allow modern drive line use. Also could folks tell me what drive line they used. I understand I will have to be cut but I would like a starting place. Thanks as always for the help
Just have a small diameter driveshft made. I think dad used a 2" or 2.5" driveshaft in his years ago.
Master vers Standard. Same only different. I have a Standard. As I remember the stock frame did not have an X-Member. Just a crossmember with a short diagonal leg on each side. Everything related to installing 350-350 gets hand built. You can use the stock rear springs if you want it to sit like a Stock 34. If you want a good stance and tire fit those go in the scrap pile also. That transfers then to the front stuff. This job grows as it goes. It's not just Nutz-n-Boltz.
