Hot Rods 34 Chrysler front suspension.
Discussion in 'The Hokey Ass Message Board' started by dartracer, Nov 5, 2021.
  1. dartracer
    dartracer
    Will the front suspension on a 34 Chrysler handle a small block and handle ok on the road? Also what about the stock juice brakes?
  2. 31Apickup
    31Apickup
    A small block most likely weighs less than the original engine.
    dana barlow and X38 like this.
  3. john walker
    john walker
    Might put a 331 hemi in my '33 Royal 8. The parallel leafs look like they will work. We'll see about the brakes. All new, should be fine if you don't drive stupid.
  4. $um Fun
    $um Fun
    from Nor Cal
    I believe the 34 Chrysler has 14" drums, they should be able to stop you.
  5. Yes, yes and yes...
  6. In regards to the modification of a small block engine update, it sure sounds like it is a GO!
  7. dartracer
    dartracer
    Thinking about maybe buying this car. Just trying to figure out what all I will need to do to make it a better driver. Seller says other than motor and trans, its all stock. Wheels have to go. 1934-Chrysler-Other Chrysler Models-antiques--Car-101630318-82f280fc5db202abbd695bd58d2e651d.jpg
  8. dana barlow
    dana barlow
    from Miami Fla.
    The first race car trailers I ever built,in 1964 was a one* axles homemade trailer out of free stuff I could find to build it out of,open flat platform thing,it worked great for over a year,when there was big race I wanted to tow up state a about a 100 miles too. So desided to repack the old wheelbearings again,an looking at them,thought"just go buy some new wheel bearing!.
    I has no idea what the old axle even was,only that it was big an heavy duty,but the Bearing place looked up the Timken #'s on old bearings, an told me that it was a 1937 Chrysler Crown front axle. I had kind of thought it was out of a truck,when first dragging it out of the woods. That thing worked fine for me,tell I sold it 2 years later. To build another race car trailer with some even better **** I had found.
    stillrunners likes this.
