Technical 34 coupe on a 32 frame?
Discussion in 'Traditional Hot Rods' started by dumprat, Aug 12, 2017.
  1. dumprat
    dumprat
    from b.c.
    Anybody got a picture of one? Old or new.?
  2. ls1yj
    ls1yj
    from Kentucky
    Dumprat
    Go look at the Whiskey Runner that jimmy shine built for Billy Gibbons. It's a 33/4 on a 32 ch***is
  3. ls1yj
    ls1yj
    from Kentucky
  4. alchemy
    alchemy
    That coupe is not on a 32 frame. You can tell itsa a 34 by the profile.
    cactus1 likes this.
  5. sloppy jalopies
    sloppy jalopies
    1933-'34 wheelbase = 112" ... 1932 ch***is = 106"...
    maybe slide the rearend back, CEE the frame if it needs it... front crossmember and ****** mount forward just a tad...
  6. ls1yj
    ls1yj
    from Kentucky
    Alchemy,
    It may not be a 32 frame complete, as I never saw a reveal under the rockers, but the front half from doors forward is duece
  7. Ric Dean
    Ric Dean
    from Central NY
    Mercy!
    Runnin shine and ls1yj like this.
  8. sloppy jalopies
    sloppy jalopies
    maybe a '32-'34 frame splice... that would let them buy the missing 6" ...
    ls1yj likes this.
  9. JimmyD3234
    JimmyD3234
    from PA
    very cool looking :cool:
  10. dumprat
    dumprat
    from b.c.
    Although I am not a fan of shines work, I could be a big fan of the brunette driving his truck.
    Anybody got and old pics of such a car? Thinking east coast style.
    Stogy and kidcampbell71 like this.
  11. HOTRODRONNY
    HOTRODRONNY
    MYSELF AN MY BROTHER USED A FRAME FROM SAC DONNIE MC NEIL THAT WAS 32 RAILS FROM FIREWALL FORWARD 33 34 FROM THERE BACK FOR HIS 34 HIGH BOY SORRY I CANT FIND A PHOTO WILL POST ONE LATER
    hallrods likes this.
  12. Runnin shine
    Runnin shine
    If I recall correctly I think the Whiskey Runner just has the front frame horns altered for the "32" look.
    ls1yj likes this.
  13. If one were to simply drop a 33/33 on a 32 frame it would not fit.
    Grafting the relatively straight 32 frame horns onto a 33/34 frame would change the stance, raise the ride height, change the profile of the inner fenders and allow a 33/34 grill to fit even with the body being lowered and channeled.
    ls1yj likes this.
  14. Runnin shine
    Runnin shine
    A year ago when finishing up the fab work for my 32 frame to fit my altered 34 Tudor body I could have spouted off all the measurements of both a 32 and 33/34 frames. One of the areas where a 33/34 is using up the extra 6" in wheelbase is behind the B pillar. On all of the body types I would say you can tell in the lower front quarter panel reveal its longer than 32s. A 33/34 is actually shorter than a 32 up in the engine bay measuring from the front crossmember center line back to the trans or pedal mount on the center crossmembers by 2.5".
    A 33/34 frame is a 1/2"(44"vs43.5") wider than 32 at its widest and stays at 44" from that fat middle section all the way to the back where a 32 coke bottle back down by 4".
    ls1yj likes this.
  15. dumprat
    dumprat
    from b.c.
    Actually I have a set of 7 degree upswept 32 rails. So they are very close to the 34 contour.
    Sort plotting evil ideas for my next build. It certainly won't be a cookie cutter job that is for sure.
    Runnin shine likes this.
  16. ls1yj
    ls1yj
    from Kentucky
    Keith Hill's Federale Coupe is a model 40 on a 32 ch***is, albeit not a stock frame
  17. ls1yj
    ls1yj
    from Kentucky
  18. manyolcars
    manyolcars
    This car looks a thousand times better than the horribly over-chopped car in post 3
    Tim and SquintBoy like this.
  19. X38
    X38
    Maybe it's the shot, but I have thought this before about this car (maroon coupe)...the roof crown and general roof height looks enormous compared with the window opening.
    29EHV8, ls1yj and Runnin shine like this.
  20. doliak
    doliak
    This one is a hybrid 32/33-34 if I remember right Gene used 32 rails from just under the cowl area forward.
    Sent from my SM-G935V using The H.A.M.B. mobile app
    kidcampbell71 likes this.
  21. kidcampbell71
    kidcampbell71
    Damn. That's ^^^ a bad mother f#cker.
