Technical 34 Coupe seat project
Discussion in 'The Hokey Ass Message Board' started by F-head, Feb 3, 2021.
  1. F-head
    F-head
    Here’s my 34 coupe seat I built up from a stock seat pan,first I made new plywood back, base, and carriage boards
    I used furniture webbing on the base 48AFA3E3-E717-4954-9DBA-DE3FD2DCBCC2.png 15FE9592-51DC-4B1D-99B4-8E362462348D.png 9AA01FF5-4989-4A68-8FC9-1400798898F4.png
  2. F-head
    F-head
    Then I used a bandsaw to cut new cushions from 6” dense foam, adding a 1/2” dense foam horse shoe bolster 1AB8973B-3D99-4E81-8E57-698A9362E5F9.png F12F8427-BDC3-4260-9FC1-3BA2C58E7807.png
  3. F-head
    F-head
    Then I sewed vinyl covers with listing, I put tuck wires into the foam to hog ring the listing to, 73F44561-2F5B-48AE-8649-63BEBD99A388.png 0A374D90-87B3-4D62-8ACB-AA6067651948.png BAEE3376-E4EA-4D1E-8C3F-EB311B30571F.png 53E68B34-9660-44FD-9B22-BC457CF276A7.png this creates shape and separates a flat seat cover from true a true tuck and roll job
  4. F-head
    F-head
    Then I put it in my never ending 34 coupe project 2A821F83-61F1-444B-92BB-3F718197017C.png
  5. F-head
    F-head
  6. sawbuck
    sawbuck
    from 06492 ct
    nice work !
  7. X38
    X38
    Nice job! Between the seat and the wheel I'm getting a good vibe.
  8. clem
    clem
    Very Nice, - we need more threads like this. Thank you !
    I have always wondered how comfortable these ‘all foam’ seats are on a long trip, compared to original spring type seats with very little, if any foam on them ?
    Any comments ?
    Also you mention ‘dense’ foam. Is there any kind of rating on the density to identify which foam to use ? And how important is it to have the cut out section and webbing ? Thanks.
    loudbang, Happydaze and gnichols like this.
  9. F-head
    F-head
    53 pound foam on the cushion
    35 on the backrest
    The bolster is all 53 pound
    The cutout with webbing helps as far as I know
    Never tried one without
    As for comparing to original springs
    I’m sure a sprung cushion would last longer
    But these last pretty well and usually the spring seat is way too high
    loudbang and clem like this.
  10. X38
    X38
    Very important. It provides 'give' and breathing.
    kidcampbell71 and clem like this.
  11. brady1929
    brady1929
    Awesome.
  12. 51box
    51box
    from MA
    Wow that’s very nice. @F-head would you mind sharing how to do the tuck wire in the foam? When I made my first seat I tried to get that roll of the horse shoe but couldn’t figure it out. Thanks
  13. da34guy
    da34guy
    Just built this 1 with plywood, foam and webbing last week for a roadster 2021 black roadster guts.jpg
  14. Nice job...as a beginner to the upholstery side of car building, I really appreciate threads like this.
    "Then I sewed vinyl covers with listing, I put tuck wires into the foam to hog ring the listing to,"
    Can you go into more detail (or photos?) on your statement above...that part still seems like magic to me...how do you determine how wide the listing needs to be to get the propet amount of tuck? How and were do the tuck wires get placed? Is the foam cut for clearance of the listing? How deep etc.
    Thanks again. Excellent thread.
    kidcampbell71, loudbang and clem like this.
  15. alchemy
    alchemy
    Yeah, more explanation on the wires. Are they curved to go all the way around the outer edge of the insert, or just the straight runs?
    kidcampbell71 and loudbang like this.
  16. Nice style!
  17. F-head
    F-head
    I cut a 1 1/2” deep slit in the foam where the cushion meets the horse shoe bolster it’s very important to make sure the slit is cut to an even depth
    I used edge wire bent to the shape of slit
    Shove it down into the slit using ****on twine shoved thru the foam with an upholstery needle, pulled tight and fastened on the bottom with staples or tied to paper wire,
    The lister is made from decking material and is sewn with a channel
    Best to cut the listing on the bias so it doesn’t unravel
    Sew the channel first then sew the lister on to the cover at the seam where the pleats meet the roll
    Should finish out at 1”
    That way you have 1/2” of pull down into the slit
    The channel on the lister gets paper wire which is hog ringed to the edge wire buried in the slit
    Start in the middle and work out always
    Hope this helps
    Bruce
  18. Cool...thanks.
  19. F-head
    F-head
    Here’s a seat with spring cushion and back rest I did for a friends 32 5 window
    On a spring seat the tuck wire is hog ringed to the top of the springs after the burlap underlayment is in in place 351FCD81-D7DC-4D97-AC0C-AED9DFDFC781.png
  20. brady1929
    brady1929
    Wow, amazing. What colors are the 32 5w seat?
  21. Pete
    Pete
    Beautiful
  22. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Fantastic work! There's just something about a stock style seat in a 34 Coupe that looks so "right"!
    brady1929 and loudbang like this.
  23. ronzmtrwrx
    ronzmtrwrx
    Nice work. Love those colors.
  24. clem
    clem
    thank you for the informative reply.
    Just looking at doing something to mine now. This all helps.
    (I have a very comfortable van seat and a stock model a seat, and trying to figure out which to modify to suit).
    fegsta and loudbang like this.
  25. loudbang
    Looks comfy :)
    brady1929 likes this.
