34 Dodge subframe
Discussion in 'Off Topic Hot Rods & Customs' started by holepatcher, Dec 17, 2024.
Tags:
  1. Yes
    0 vote(s)
    0.0%
  2. No
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. holepatcher
    holepatcher
    from Tennessee
    Has anyone ever used a S10 front end as a subframe for a 34 dodge/plymouth? Thanks
  2. 31Apickup
    31Apickup
    Subframes whether it’s S10, Nova, Camaro are all wrong for an early 30’s car.
    lemondana and Bentrodder like this.
  3. gene-koning
    gene-koning
    This needs to move to the Off topic section.
    Eons ago I put a Volare subframe under a 35 Dodge sedan. Even full fender, it was too wide, I ended up widening the nose 4". The Nova and the Camaro would have the same problem.
    The S10 may have a narrower track width, but the steering box will be very visible and the shape of the frame is all wrong.
    lemondana likes this.
  4. holepatcher
    holepatcher
    from Tennessee
    Thank you
  5. flynbrian48
    flynbrian48
    That's a really terrible idea. On so many levels.
  6. dwollam
    dwollam
    The independent front suspension on a '33-'34 Dodge/Plymouth is not too bad of a system. Maybe add modern shocks. This is ***uming full fendered. I cut the front suspension off my '34 DB frame because I was building it fenderless. Spliced on and boxed '37 DB pickup front frame rails and a cross spring with a Model A type crossmember.
    The HAMB does not allow front clip swaps swaps except in the "Off Topic" section.
    Dave
  7. scotts52
    scotts52
    If you or anyone else are cutting off the front of a 34, I could really use all the steering components. It would be nice to be able to actually steer my project around
