34 Ford 3 window question
Discussion in 'The Hokey Ass Message Board' started by Bosco1956, Jun 4, 2009.
  1. Flathead
    37 vote(s)
    29.6%
  2. Olds Rocket 324
    66 vote(s)
    52.8%
  3. Sbc DZ302
    22 vote(s)
    17.6%
  1. Bosco1956
    Bosco1956
    from Jokelahoma
    I just got a 34 3 window chopped & channeled. It has a flathead in it but is just a mock up block. I can't decide if I want a flathead,olds rocket or a sbc in it
  2. Cliffy
    Cliffy
    I can tell you for sure SBC is the cheap way out.
    Y-Block is my preference of choice.
    Flathead is cool, but olds rocket would be nice.
    Just don't go SBC whatever you do.
    Nailheads look killer as well.
  3. cuznbrucie
    cuznbrucie
    One consideration that you must think about is the driveline.......that rearend is an open drive rear, so that means you cannot run a traditional old Ford trans and torque tube....
    Consider the Olds, Cadillac, Buick Nailhead, or Y-Block Ford with a suitable transmission and driveshaft...... Suggest a T-5 for the Overdrive it has........
    CB
  4. bfink55
    bfink55
    from Turlock CA
    sbc........just to piss most people here off , bonus points for a 302, but if its a real DZ id sell it to Z-28 resto guy for big bucks and build a de-stroked 327 (gotta have a muncie 4 speed too)
    FINK
  5. ss34coupe
    ss34coupe
    My vote is for the flathead, with the Olds second choice. But I would change the rearend you've got to something that would better match the era of those two engines. Looks like a great project.
  6. BrandonB
    BrandonB
    from nor cal
    324 Olds w/4 spd hydro. Can't get much tastier than that.
  7. fab32
    fab32
    There will be a lot of hate by suggesting the SBC, but if it were done right I don't think the final result would get too much negative feedback. Now, by being done right I mean either a Rochester fuel injected 283 or 327 dressed just like they would have been removed from a '57-'65 Corvette, a 4-71 or 6-71 blown 327 w/dual AFB's and vertex mag and Hedman hedders, or (the cheapest) a 265 or 283, Rochester or Carter 4bbl stock dressed with tin covers and ram horn exhaust. The last one would have to be painted Chevrolet orange and wear a stock air cleaner and Delco Remy distributer with the wires running down the back of the engine and routed up to the plugs from below. A visible gl*** fuel filter and a generator would be mandatory.
    Frank
  8. Strange Agent
    Strange Agent
  9. fab32
    fab32
    I'd also get rid of the 4-bar front suspension and go with split bones or wishbones and get the front down with a deeper dropped axle and/or pie cut the frame just in front of the firewall. With that chop you might consider a set of Halibrands with tall skinny bias plys.
    Frank
  10. i am a huge flathead fan, when i saw the overall styling of your coupe I thought Flathead for sure, but with that rear end I would opt for Olds.
    Great looking car by the way. If it was mine I would QC it with a flathead.
  11. Floorboardinit
    Floorboardinit
    Overhead olds would have been the motor for that car back in the day. John
  12. Weasel
    Weasel
    Another vote for the 'Rockay'
  13. Bosco1956
    Bosco1956
    from Jokelahoma
    Plans are to change the front end to split bones super bell axle a 40 ford rear end and maybe do a quick-change. I have a 324 olds 3 deuce and a hydro. I also have the 302 and 265 283 or 327 I have a friend that has a stock 34 frame and plan to remove the frame that is under it.I don't know much about the history of the car other than it was built in the 40s or 50s then some yahoo removed all the good stuff and replaced with what you see now
    I am leaning toward the olds. And I would like to run a manual trans. Also plan to use the 3.5 40 ford wheels that are on it.
  14. Bosco1956
    Bosco1956
    from Jokelahoma
    Looks like we are going to do the Flatty with a 39 transmission. We stuck a set of bent spoke wires on it yesterday. :D That improved things also a tattersfield intake. Give me more ideas please. Looking for a 40 rear-end. I have located a set of thickston heads,head covers,intake and breather.
    What ideas do you guys have on colors. :confused: I already have several cars hot rod black and am looking for something different.
    Please keep the ideas & opinions comming
  15. Verne
    Verne
    from Burbank
    Sounds like your going in a good direction to me!
  16. ian
    ian
    I voted flathead. The flathead just looks at home in mock-up mode. But then what do I know? I'm a HEMI guy. ;)
  17. captainjunk#2
    captainjunk#2
    the flatty would be cool , olds rocket would be cool to sbc would be cheap and cookie cutter but its your car and your decision in the end
  18. belair
    belair
    Can't go wrong with any of them. All dress out nice and all are traditional.
  19. bubba67
    bubba67
    from NJ
    Go with the flathead ! I love the car, similar to mine.
  20. bonesy
    bonesy
    Great looking car. I would go OHV with that rear end.
    (Really I would change the rear and go with a flathead.)
  21. Hot Turkey
    Hot Turkey
    You should put a Ford in a Ford!!!
    Amen.
  22. Flying Tiger
    Flying Tiger
    from Japan
    I'd take the Flathead any day. My second choice would be the Olds Rocket. I would only use the SBC if I was on a really tight budget.
  23. Docco
    Docco
    from Ippy
    Its a no brainer - flathead.
  24. 56don
    56don
    I think you made the right choice.If you wanted your car to look just like every other Tom **** and Harry,then the chevy would have been ok.But you are showing you have some original thinking. Good choice.Now if you could just find a quick change for a reasonable amount............
  25. greasy50chevy
    greasy50chevy
    what about a cad?!?!?!?!??!!
  26. 57tony31
    57tony31
    from Woods
    The way the talk is around here you going with a sbc would be rare.:) Its all flat heads and nailheads.So you should play it safe and go with the rare sbc :)
  27. Bosco1956
    Bosco1956
    from Jokelahoma
    Good looking car. :D
  28. BanjoBoy
    BanjoBoy
    Go with the Road less traveled........Flathead For your HOT ROD!
  29. Steves32
    Steves32
    from So Cal
    Oh- that 4 bar fron suspension is too street-roddy. It will never be traditional. Let me come by & take it off your hands.
    No.... I insist.;)
  30. Comet
    Comet
    If you are going for an early late 40's/50's look-flathead. Anything after about 1955 Olds (even though the Rocket motor was available before that, availability, speed equip. etc made it a rare option for rodders prior to 1955 or so).
