34 ford bolt pattern
Discussion in 'The Hokey Ass Message Board' started by rustydogs, Dec 9, 2010.
  1. rustydogs
    rustydogs
    from canada
    hello what is the bolt pattern on a 34 ford.is it 5 x 5.5? looking for wheels.. possible to use adaptors and just use other wheels.. on a stock 34? want to puts some steelies and wide whites..
  2. rustydogs
    rustydogs
    from canada
    thx so ill have no probs running stock 5 5.5 15" rims then on this..
  3. R Pope
    R Pope
    Why not convert to juice brakes and get rid of those hubs?
  4. There are 5 raised areas on the stock '34 hubs. These areas are next to each stud. If you run the later Ford (1940-48) wheels you need to add a ring to get the wheels to seat properly on the hub. Watch out for this problem when getting adapters. Just a suggestion without seeing your car but bent spoke Kelsey's bolt right on.
    Charlie Stephens
