Hot Rods 34 Ford cabs
Discussion in 'The Hokey Ass Message Board' started by rats28, Nov 28, 2016.
  1. rats28
    rats28
    from Louisiana
    Im looking to purchase a 34 Ford cab.... The question is are the 1/2 ton and 1.ton truck cabs the same?
  2. rcnut223
    rcnut223
    from wisconsin
  3. timwhit
    timwhit
    Yep. This is one that I removed from the 1 ton frame and put on the '32 frame. '34 cab, '32 frame. I drilled the spot welds out of the firewall and moved it back a little 100_0004.JPG since I used a p*** car grill and hood.
    rats28, LOST ANGEL and low budget like this.
  4. Hitchhiker
    Hitchhiker
    I've heard even the front fenders and running boards are the same
    Can anyone confirm this?
    Sent from my SM-G900T using The H.A.M.B. mobile app
  5. scotts52
    scotts52
    From what I understand, the fenders on a 32 are all the same. Car, truck, 1 1/2 ton etc. I've also been told that the 32 fenders will not fit on a 34 frame unless you replace the fender supports with those from a 32.
    I cannot confirm this though.
    Hitchhiker likes this.
  6. Hitchhiker
    Hitchhiker
    I'm wondering if 34 big truck fenders fit the little ones.
  7. alchemy
    alchemy
    32 fenders won't fit a 33/4 frame at all. And vice versa. The fenders look a whole lot similar, but they aren't. Just changing the braces won't do it.
    I've heard that the spare tire well on the big trucks is a different size than the pickups, but the proper year fenders will interchange otherwise.
    The 33/4 big trucks (flat beds) had short running boards, didn't they? So they wouldn't reach all the way to a rear fender. Probably the same on a 32.
  8. rats28
    rats28
    from Louisiana
    Thanks guys!!!
  9. Chris
    Chris
    You can tell 33/34 pickup/large truck fenders as they have a small raised "rib" that goes over where the front cross member raised rivets are. 32's do not have this feature.
    32 fenders, headlight bar and hood, and firewall are the same on car, pickup and large truck. cab is the same pickup and large truck. Car and pickup share the same running board, however the pickups are metal and car had a rubber skin.
    33-34 pickup and large truck share the same fenders, hood, headlight bar and cab, but the running boards are short on 32-34 large truck. 33-34 pickup had the gas tank in the back, large truck it was under the seat. About the only difference in the cab.
    scotts52 and Hitchhiker like this.
