Hot Rods 34 Ford pedals in a 32
Discussion in 'The Hokey Ass Message Board' started by WiredSpider, Oct 30, 2015.
  1. WiredSpider
    WiredSpider
    Is it possible to use a 1934 Ford Pedal ***y in a stock 1932 Ford Frame?
    If so what modifications do I need to do?
    Is the pedal bracket the same and do I just need to modify the pedals?
    Thanks
  2. bct
    bct
  3. alchemy
    alchemy
    The bracket is different, and the pedals are different. But they are all similar, so if you could borrow a 32 set to use as an example, the mods could probably be done without too much head scratching. Depending on your steering and engine placement, you might actually be able to bend the pedals to fit better than stock anyway.
    It's just cutting, bending, and welding. Sounds easy enough.
  4. Deuce Lover
    Deuce Lover
    I believe the 33-34 pedals will work in a 32 bracket.The 33-34 pedal arms are shorter so will bring the pads a bit further back from the firewall..
  5. MN Stumpjumper
    MN Stumpjumper
    [​IMG] I make these,a repo 32 bracket. 34 pedals fit. Modify pedals to work for your application.
    bct and StrickV8 like this.
