Projects '34 Ford PU I've been workin' on...
Discussion in 'The Hokey Ass Message Board' started by ClutchDumpinDan, Sep 14, 2011.
  1. nitrohonkey
    nitrohonkey
    I really approve of your reinforced bracketry at the shackle mounts on the front wish bones. Looks like it should be rigid. Good job!
  2. speedfreek155
    speedfreek155
    Great Job ! Keep us posted , that is gonna be one sweet pick-em up when you are done .
  3. ClutchDumpinDan
    ClutchDumpinDan
    I really wanted to run the stock transverse spring in the rear. After getting it all mocked up, here's what I came up with for a spring perch...
    I stared at it for a long time and didn't like it. Finally decided to go to Plan B...(gasp) coilovers :rolleyes:
    Here's the four link all tacked in and checked for bind, clearance issues, etc.
    And here it is all done and painted. Sorry, no progress pics, I was on a time crunch so I could get to Hershey :D
    And here it is in roller form out in the daylight...sportin' the hubcaps I picked up at Hershey too :)
  4. ClutchDumpinDan
    ClutchDumpinDan
    Started on the bed today. Got the tailgate at the Hershey swap meet last week.
    The plan...
    The layout...
    Driver side panel done...
  5. ClutchDumpinDan
    ClutchDumpinDan
    Got the front bed panel made up...
    Then made the frame work out of 3/4" square tube...100% TIG welded, that took awhile :)
    Next up I welded the frame work to the sheetmetal...
    Made a hole for the driveshaft too, still gotta cut the cab...
    Here's the filler panel for below the tailgate. Looked kinda blan so I decided to mount some '54 Buick taillites in it.
    All welded up and ready to mount. Definitley more truck looking now :cool:
  6. house of fab
    house of fab
    from ashland va
    Looking good Dan. What gauge sheet metal did you use? Whats the length of the bed?
  7. ClutchDumpinDan
    ClutchDumpinDan
    Thanks Dave!
    It's 40" long. All the sheetmetal is 16ga.
  8. draggin1958
    draggin1958
    Freakin love it man looks great
  9. scottb356
    scottb356
    *****in ! Is that a traditional word ??:rolleyes:
  10. scottb356
    scottb356
    The truth is out there...........:p
  11. ClutchDumpinDan
    ClutchDumpinDan
    Tailgate hinges...
    I thought they were done...then D-Russ saw them and convinced me they needed the ends closed...and that they HAD to be round :rolleyes:
    He was right though, thanks Dave! :D
    On the truck...
    Tailgate latches...
  12. moprr71
    moprr71
    Looks good. Keep it coming.
  13. terd ferguson
    terd ferguson
    Dan, I'm digging this so far!!
  14. wow, awesome skill! your truck is looking great!
  15. Desert_Rat
    Desert_Rat
    Very cool build!! Thanks for sharing!!
    ~Dustin
  16. travj31
    travj31
    from Western PA
    great job... starting my 33 pick-up this fall and will probably use a few of your ideas. thanks!
  17. ClutchDumpinDan
    ClutchDumpinDan
    Think it through and go for it, what's the worst that can happen? If somebody else can do it, why can't I? :D:eek:
    Dont be a ****................****! :)
    Thanks!
    The more I learn the less I know :eek:
    Thanks Terd! I gotta see and hear your Caddy motor in person one of these days!
    Thanks Skater!
    Thanks Dustin! Nothing better than looking at build threads...just trying to do my part :D
    Cool! Look forward to seeing some pics of it.
  18. ClutchDumpinDan
    ClutchDumpinDan
    Here's what I came up with for tailgate latch holder things.
    1/2" allen head bolt and a ****on head bolt of un-remembered size.
    TIG'd the center solid...
    Cut the ****on head off and TIG'd it to the 1/2" allen...
    All ground down and smoothed out...
    TIG'd on a piece of chain...
    On the truck...
    The fit is tight enough that you have to give it a little side to side twist to get it in, so I'm not worried about it popping out going down the road....hopefully :)
  19. oj
    oj
    As Frank Lloyd Wright put it 'God is in the details'
    Very nice work, creative.
  20. scottb356
    scottb356
    looking good mang
  21. Martin_F
    Martin_F
    Nice Dan!
    You could always drill a hole through the thread in the bottom of the bolt and add a safety pin.
  22. BISHOP
    BISHOP
  23. OahuEli
    OahuEli
    from Hawaii
    Thats a pretty cool solution for the tailgate latch holder thing.
  24. hammeredrods
    hammeredrods
    great truck , you do awesome work dude.
  25. chappys4life
    chappys4life
    from Austin, TX
    Dan you are always are working on some sweet toys and your fab work is top notch. Looks good for sure!
  26. LOVE IT ! more pic as you go
  27. rat pup
    rat pup
    from houston
    Thats a bad *** ride! Great Skills friend
  28. rjgideon
    rjgideon
    Dan, that's great work there. It looks like a '40 axle you are using up front. Are you going to run into problems with the tires hitting the wishbones after you split them? How wide is your frame?
    I am planning to build a frame for a '27 roadster soon with a '40 axle myself and was worried about the wider turning radius so I figured I'd ask you. Great work again, I am subscribing!
  29. 1 KooL "MoFo"
    1 KooL "MoFo"
    Grate work ! Post more pic's
  30. ClutchDumpinDan
    ClutchDumpinDan
    I measured the frame as best I could with the engine in the way. It looks to be around 29" wide where the wishbones mount.
    Obviously I haven't had it on the road to try out yet but from pushing it in and out of the garage, moving around the driveway, etc. it seems to have a sufficent turning radius. It certainly won't be as tight as a compact car but I don't belive it's gonna take a 40 acre field either :D
