34' Ford wire wheels? bolt pattern?
Discussion in 'The Hokey Ass Message Board' started by steevil, Dec 8, 2005.
  1. steevil
    steevil
    What bolt pattern would 34" Ford wire wheels be?
    What can you do about mounting them on modern style disk brakes? Is there an aftermarket drum retainer available or would this be a Custom fab deal?
    I found 6 Kelsey Hayes wire wheels. These are 3 ½ X16 inch, 32 spoke rims. They are good originals from a ’34 Ford. One has side mount cover.
    Thanks for any advice.
  2. 97
    97
    33/34 Ford wheels are 17" 35s are 16"
    You need drum brakes for Ford wires.
  3. Your 3 1/2 x 16 wheels are not 35 Ford. 35 Ford were 4 x 16 with 5-5 1/2 bolt pattern. What is the bolt pattern on the 3 1/2 x 16 that you have? Maybe we can determine what they are for.
  4. steevil
    steevil
    I am regurgitating what the advertisiment read. apperantly the seller is in error. I would still love to have a set for my model A though...
    link to the ad below...
    http://www.canadatrader.com/usedcar...icesaccessories/15918664/partsdetailinfo.html
    I've sent him an e-mail requesting the bolt pattern but I'm guessing that it's going to be 5 x5½"
  5. The width may have been mis-stated, they may be 4".
  6. The only Ford/KH wheels with 16 x 3 1/2 were 1937-38 with 5-10 1/4 bolt pattern. The picture in that link don't look like that, so...........he'll have to re-measure for you. The two wheels pictured look like paint over rust, or it's a bad picture.
  7. Do you have disc brakes on your A now?
  8. steevil
    steevil
  9. Kevin Lee
    Kevin Lee
    Super Moderator
    Those are not 16" wheels. Might sound a little strange but you can tell just by looking at the space between the hub and rim that they are at least 17".
    Also - Ford did make a few 3 1/2 x 16" steel wheels with a 5 on 5.5 bolt pattern. V8-60 equipped '40 Fords came with them. I think Vaphead owns a couple?
  10. You need to be careful about buying those without an exact measure, as there were some mid 1930s chevy and chrysler that had 16 and 17 inch with 5x4 1/4, 5x4 1/2 wires.
  11. 97
    97
    They look like standard 33/34 Ford 17s to me not Kelseys.
  12. Yes, Ford manufg, but not KH. 40-41 V-8, 1/2 ton, and 40 Mercury, disc, but not wire spoke,
  13. Yes, 17x31/4, wire. ford mfg. KH didn't make any of those.
  14. steevil
    steevil
    heck, for $200 Canadian dollars for 6 of them....a guy can't really go wrong.
    Shipping would be a ****** though....About 30 lbs each I reckon. 180 lbs shipping weight. yow!
  15. Zodoff
    Zodoff
    If thats Ford wheels, its 17'. Spokes are shorter on 16's.
    34 would then be correct.
    Dont think they'll be good for discbrakes,atleast not without some kinda big adapterplate.they need good support.
  16. steevil
    steevil
    Thanks for all your help folks!
    The guy hasn't e-mailed me back yet...I'll update when I have more info.
