History 34 pickup cabs all the same?
Discussion in 'Traditional Hot Rods' started by kustomdeluxe, Feb 19, 2022.
  1. kustomdeluxe
    kustomdeluxe
    Are the standard pickup cab and the 1.5 ton dually cabs the same? how about grills and hoods?
    thanks for any help on this
  2. verde742
    verde742
    i think they are the same with different front fenders..
    kustomdeluxe likes this.
  3. alchemy
    alchemy
    Verde is right. I'm pretty sure the difference on the front fenders is a wider well for the spare on the big trucks.
  4. Nobey
    Nobey
    Yes they are the same cab, the fenders are the same ,with the exception of a stamped bump to clear
    the rivets on the big truck frame and the flange is a little wider on the frame rail. The grilles are the
    same, but the big truck is heavier gauge steel and weighs 7 more pounds then the pickup, they fit the
    same though. The hoods are both the same. Truck running boards and pickup boards are different.
    Hope this helps
  5. kustomdeluxe
    kustomdeluxe
    Thanks guys! exactly the answer i was hoping for.
  6. sloppy jalopies
    sloppy jalopies
    memory says '33s had 2 cabs, something about the roof bead...
    they both bolted to the frame the same way...
  7. hotrodjack33
    hotrodjack33
  8. The '34 has a different wider beltline stamping across the back of the cab than '32 and '33. '32 firewall bolts in, '33 and '34 is welded in. Mac Hils' book details all the differences between the '32, '33, and '34 cabs.
    Jeff34 and MO_JUNK like this.
