34 rear end swap
Discussion in 'The Hokey Ass Message Board' started by krazyk, Oct 15, 2012.
  1. krazyk
    krazyk
    Does anyone know of a good ford rear end swap to put in a 1934 ford with a flatty V8 and T5???? Or a manufacture the makes and org. looking one for highway driving??
  2. millersgarage
    millersgarage
    I do not know, but I am building the same thing, and would like to know as well.
  3. I just measured the axle under my 57 ford pickup box trailer. It's about 58 inches flange to flange and with a wheel with 4 inches backspace,it gives me about 2 inches clearance from rim to inner fenders per side. Chassis Engineering sells a parallel leaf spring kit for 33-34 fords. .
  4. Aviator
    Aviator
    '76-'77 Ford Bronco 9" is a great setup
  5. ibuild
    ibuild
    8.8 ford rearends, i have used them in my last 2 builds, 29 roadster and 38 pickup, i like the disc brakes
  6. What is wrong with using the stock banjo with an open drive conversion? Look at Hot Rod Works for everything you need to make the banjo rear do all you need.
    The T-5 lets you run the stock banjo gearing and have great cruising rpms.
  7. ss34coupe
    ss34coupe
    The Bronco rear like Aviator says is a good fit. I have a 57 Ford nine inch in my 34 Ford coupe, and it fits perfectly. The early 70's 8 inch would probably fit as well.
  8. 345winder
    345winder
    damn it...i thought no one carried/made an open drive conversion for the 32-34 axle(i.e. speedway/dick spardo),,,so i went with a 66 bronco 9" rear instead..oh well, you live and learn...
    btw, i have a clean low mileage 34 banjo rear for sale cheap!
  9. 343WINDOW
    343WINDOW
    What's the measurement flange to flange on that Bronco diff?
  10. 48 Chubby
    48 Chubby
    Also Winters makes a banjo style non-quick change unit now.
  11. krazyk
    krazyk
  12. BELLM
    BELLM
    I'm running a '77 Ford Maverick 8" with the Chassis Engineering parallel leaf conversion, like Reggie runs ib his '34. Direct bolt in except had to elongate the holes in the spring pads about 1/4inch. Rides so much better than the stock 34 spring. I think the stock gears are around 2.90.
  13. 31Apickup
    31Apickup
    The 66-77 Bronco rear is 58" from wheel mounting flanges. A Maverick rear is 56".
  14. GREAZERZ
    GREAZERZ
    from Frisco, TX
    As stated above the ford 8.8" and 9" flange to flange measurements will get you there. New axles fairly inexpensive and easy to get and install from mutliple manufacturers. Used a '74 Maverick with standard backspaced wheels from Wheel Vintiques and they fit awesome!
  15. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    Maverick 8" here. Perfect fit.
  16. Hotrodmyk
    Hotrodmyk
    This is, indeed, a sweet setup and the ride is good. Stock gears are 2.73 and 3.00 depending if the rear end came out of a stick shift or automatic car.
  17. outlaw256
    outlaw256
    ok where the hell is hillbilly heaven?
  18. RDP
    RDP
    from Kansas
    So does your drive shaft run at an angle? or did you cut one side down to even it up?
  19. 345winder
    345winder
    southern kentucky
