34 rear Xmember pie cut ?
Discussion in 'The Hokey Ass Message Board' started by sawbuck, Feb 18, 2008.
  1. sawbuck
    sawbuck
    from 06492 ct
    i need some info on how to flatten a rear cross member 34 ford truck.i need to drop the rear end. running a stock spring, 8 in rear with CE spring brackets.i removed 5 leafs it did not lower it enough.i need 2 or 3 more inches of drop.looking to run fenders so i dont want a tail drager.thanks for any help
  2. Kevin Lee
    Kevin Lee
    Super Moderator
    Here is where NealinCA did it. Unfortunately the pics have expired, but if you can search out a post with pics of his ch***is it's pretty self explanatory.
    Neal's rear crossmember
  3. sawbuck
    sawbuck
    from 06492 ct
    thanks kevin,good info. pics would help too.any more help out there ?
  4. sawbuck
    sawbuck
    from 06492 ct
  5. NealinCA
    NealinCA
    Here are a couple of pics...
    Hope that helps.
    Neal
  6. sawbuck
    sawbuck
    from 06492 ct
    thanks,nealin.helps a lot.
