Between the suicide doors and no windows, how have y'all mounted side view mirrors? Swan neck style drilled through the cowl or door? Does anyone have experience with the clamp on style for the window stanchions, or know of a solution to bolt on the stanchion/window frame swing bolt? Thanks in advance Gnater
I have swan necks mounted on my doors and they look really cool. I cant see a damn thing in them but they look excellent!
Some serious fabrication required so they look right.Always a challenge with 1933-34 Ford open cars .Back in 1973 when I built this roadster all I could find were windwing clamp ons.Just realized they aren't on when the Street Rodder pics were taken.Vintique at one time made a bracket that sandwiched between the cowl light and body.They have been discontinued a long time ago.A couple yrs ago I built this '33 tudor and used the swan neck as the door clamp ons would not clear the door jamb.I waited a long time before drilling the holes for them. Since the doors were done(gl*** installed and painted) I did not want to take it apart.I made plates to fit the swan necks and then screwed the plate to the body.It was tricky for placement as I wanted them to function(see out of them).Where I installed them they worked perfect.Not sure if that application would work for you.Maybe a curved bracket to attach to the windshield thumbscrew on the stanchion then a mirror head at the other end? Some sort of stop needed to maintain the bracket stationary.
