Hot Rods 340 tight fit
Discussion in 'The Hokey Ass Message Board' started by Glen Bob, Mar 6, 2022.
  1. Glen Bob
    Glen Bob
    Just installed a 340 in my 37 pickup, any ideas on headers that will fit
  2. squirrel
    Pictures?
    It's usually a good idea to get that figured out before you make the engine mounts, so you can juggle things as needed to make it all fit.
    Have you looked at manifolds or headers for a 340 in a 1970ish Dart?
  3. oldiron 440
    oldiron 440
    Buick or mopar?
    Turnipseed likes this.
  4. Last edited: Mar 6, 2022
    squirrel and pprather like this.
  5. Hmmmm, or maybe an old Skidoo 340 ;)
    Fitty Toomuch and egads like this.
  6. pprather
    pprather
  7. BamaMav
    BamaMav
    from Berry, AL
    May have to weld up a custom set.
  8. Ebbsspeed
    Ebbsspeed
    I ran fenderwell headers on a 40 Ford pickup. Maybe that would be an easier solution.
  9. earlymopar
    earlymopar
    I had a 37 Dodge pickup that I put a small block Mopar in. I built my own headers but that's not to say you couldn't find an existing set you could modify to fit.
  10. Glen Bob
    Glen Bob
    Mounts not welded up yet just trying to figure headers steering and fan
    Hnstray likes this.
  11. Glen Bob
    Glen Bob
    Looking like a custom set of headers
  12. Glen Bob
    Glen Bob
  13. Glen Bob
    Glen Bob
    I have a set of manifolds from the 69 block but drivers side gets into the the side skirt of the hood
  14. notaford1
    notaford1
    from webster ny
    340 same as any small block maybe set of block huggers or any short style
    I have stock manifolds but used these mounts if it helps. In 33 Plymouth should be about same space C3CE099F-246A-4C08-9CDD-2ADD692E8FE0.jpeg C3CE099F-246A-4C08-9CDD-2ADD692E8FE0.jpeg
  15. Glen Bob
    Glen Bob
    That looks good have the same style of mount from Welder Series thanks
  16. squirrel
    The type of steering you're using will make a difference in how things fit...so pictures of your setup will really help folks help you. We can only guess at what you are looking at.
  17. goldmountain
    goldmountain
    I put a 318 into a '41 Fargo and used the left side manifold from a '70 or so Duster. It curved up and around the steering column.
  18. hemihotrod66
    hemihotrod66
    This is why Chrysler offset there engines to the right to clear all that stuff....
  19. pprather
    pprather
  20. 73RR
    73RR
  21. dartracer
    dartracer
  22. mcmopar
    mcmopar
    from Strum, wi
    20211229_191731.jpg 20211229_164932.jpg 20211229_164951.jpg 20211229_191706.jpg 20211229_191731.jpg
    I am working on a second set of stainless one's for my truck now for my truck now. I ran my exhaust between the fender/running board and frame. It worked out pretty good for steering. I also had brakes and clutch in the way on driver side, with a battery on p***enger side, thus the reason for outside the frame. It took a while to build them as I am no professional, but i did it the work great and the truck runs hard. These are the old ones. 20211229_191706.jpg
    loudbang and squirrel like this.
  23. Oldiesmiles
    Oldiesmiles
  24. Glen Bob
    Glen Bob
    Yes it’s very tight looking at block hugger headers at Summit, they dump in the centre might be alright
    pprather likes this.
  25. pprather
    pprather
    Hnstray likes this.
  26. mcmopar
    mcmopar
    from Strum, wi
    Equal length and clocked for firing order. I know its over kill but makes me happy. Looking fo a 10 sec run this year. 20220221_192452.jpg 20220303_205723.jpg
  27. rockable
    rockable
    Patriot makes a shorty header with center dump that I used on my 41 Plymouth. It would not have worked with the stock steering gear, however.
  28. hkestes
    hkestes
    Don't know how close the engine compartment on a 37 pickup is to a 37 Plymouth car, but these are what I have in my 37 coupe. Custom made long tube headers. [​IMG]
    loudbang and slayer like this.
  29. das858
    das858
    I used off the shelf headers for '72-'93 full size 1/2 ton Dodge pickup 2 wheel drive , they fit inside the orginal frame on my '38 Plymouth pickup . Didn't have to dent any tubes , fit like they were made for it. I believe the brand i used were Hedman .
    loudbang and pprather like this.
  30. lemondana
    lemondana
    from Lincoln NE
    Your intake is on backwards, won't run like that!:D
    loudbang and SS327 like this.
