Customs 35 Ford 3-window build
Discussion in 'The Hokey Ass Message Board' started by Fomocokid, Oct 25, 2010.
  1. Fomocokid
    Fomocokid
    from Rapid City
    I made the last pieces around the ******. The top around the shifter and the parking brake is removeable. I have the toe boards welded in now. I just need to weld all of this together and then Im done with floors for now until I step the rear frame.
    mgtstumpy likes this.
  2. stlcrzn
    stlcrzn
    Looks great!!! Good to see some progress again.
  3. oldman2
    oldman2
    That's a good looking floor, super nice job.....Jim
  4. Fomocokid
    Fomocokid
    from Rapid City
    I scored a collection of parts from an old timer from my home town yesturday. The mirror with the clock and the really nice waterfall will be going in my car. I also got a dash, another set of tube shock brackets, 4 other waterfalls, a shackle kit, a set of pedal pads, a wide five hub cap, some wire wheel caps, a set of the trim that goes below the garnish moldings and a set of 36 headlight lenses
  5. Fomocokid
    Fomocokid
    from Rapid City
    I also got a spare tire holder but I dont have a pic of it
  6. oldman2
    oldman2
    Nice score on the parts.....Jim
  7. TomH
    TomH
    Cool!!! That one waterfall IS nice!!
  8. lazyv8
    lazyv8
    Wanna sell that clock mirror?
  9. Fomocokid
    Fomocokid
    from Rapid City
    No not really but if I change my mind I will let you know
  10. Fomocokid
    Fomocokid
    from Rapid City
    I finished welding the floor today and ground all the welds down.
  11. 510madmav
    510madmav
    Very nice work as usual, Let me know If you'd like to get rid of a waterfall..
  12. oldman2
    oldman2
    Floor looks super...Jim
  13. Fomocokid
    Fomocokid
    from Rapid City
    The cowl vent gutter was rusted out in my car. We have a customer car in the shop that the vent is getting filled on so I robbed the better gutter out of it. I repaird a few rust holes in it and welded the hinge brackets back on. The hole going into the drain tube was much smaller than the tube so I drilled that out and welded all the way around the tube to prevent leaks. I now have it welded into the car but not finished.
  14. 562roadster
    562roadster
    Amazing work! Let me know if you decide to sell one of them waterfalls.
    -George
  15. oldman2
    oldman2
    Very nice job...Jim
  16. Real nice job on that and worked out perfectly for you having the donor out of the customer car!
  17. TomH
    TomH
    Looking good............see ya Sunday.
  18. Fomocokid
    Fomocokid
    from Rapid City
    I ground and finished the welds tonight and I put it all together. I used an original screen out of a parts car I had. The handle is also an original that I buffed the bare steel
  19. Surf City
    Surf City
    Beautiful workmanship - it doesn't even look like anyone's been there...:D
    Bear:)
  20. farmer12
    farmer12
    Nice work on the cowl vent! Looking good.
  21. oldman2
    oldman2
    X2 super work....Jim
  22. Fomocokid
    Fomocokid
    from Rapid City
    I worked on the gas pedal tonight. I had to widen it an inch to make it line up where I wanted it. I also had to cut a hole in the firewall for it to bolt to.
  23. stlcrzn
    stlcrzn
    Looks kool!!!!
  24. oldman2
    oldman2
    Nice job....Jim
  25. Mart
    Mart
    You managed to take a 32 pedal and widen it to suit a 35!
    Everybody else does it the other way around!
    Love this build.
    Mart.
  26. Fomocokid
    Fomocokid
    from Rapid City
    The rod going from the gas pedal to the carb was at an angle and that botherd me. So I lengthened the linkage end of the pedal. Doing this also changed the ratio of the pedal for the better. It made it so I could keep the pedal closer to the floor so it looks better. I also made some new drain tubes for the windsheild since one was leaded shut and the other was gone.
  27. oldman2
    oldman2
    Nice job, look great...Jim
  28. Outback
    Outback
    from NE Vic, Oz
    You are doing some super nice work!
    G
  29. Fomocokid
    Fomocokid
    from Rapid City
    I decided that I would mount the heater while I still have the dash off. I got my heater core back from the radiator shop. The heater box had studs sticking out the back originaly, but I didnt want them sticking throught the firewall. So I knocked the studs out and welded them to the firewall. I also welded the spacers to the heater box. The defroster ducts were pointing straight at the firewall, so I am going to weld some tubing on to change the angle.
  30. stlcrzn
    stlcrzn
    Coming along nicely!!!!!!!!!!!!!!
