Projects 35 Ford pickup rear end swap....need help
Discussion in 'The Hokey Ass Message Board' started by midnight1957, Feb 13, 2016.
  1. midnight1957
    midnight1957
    Hi, I am buying a 35 Ford pickup that has the original rear end in it and I would like to swap out this rear end for one from a 1995 Ford Explorer because it is a good one to use and it also has disc brakes. The overall length from flange to flange is 59 and 1/2 inches.
    If I put this rear end under the 35 truck will the wheels stick out and if so what are my options to correct this so they don't stick out?
    Also should I get the springs that were used with the Explorer and use them on my 35 truck.
    I know you guys are the experts and that is why I am posting on here.
    Thanks in advance,
    Wade
  2. it depends on what size and offset wheels you plan on using , but i think 59-1/2 is a bit wide. 58" wide seams to work out best for `35-`40 fords
  3. Well, if you like bodywork, you could always do this. I widened these rear fenders 1 1/2".
  4. 36-3window is right. 58" seems to be the right width. 10 bolt, 8.5 rears out of Camaro's, Nova's are very close in size, Early Broncos, although getting hard to find are a great alternative too. Chassis Engineering makes a parallel leaf kit for the rear that has everything you need for a seamless install.
  5. 1946caddy
    1946caddy
    from washington
    I take it that you'll be switching transmissions and adding disc brakes to the front as well.
  6.
  7. studebaker46
    studebaker46
    I put an 8.8 rearend out of 97 mustang and used stock steel wheels off of a ranger this was on a 41 which is the same frame as your 35 and had 0 problems
  8. bjinx
    bjinx
    Stock '40 Ford is 59 1/4", Do not think '35 would not be much different since they are the same frame. I used a Ford Granada 8.8 rear end in a '40 pickup with a CE rear leaf spring kit, and 1/2" lowering blocks. I used 8 1/2" x 15" wheels with 235/75 tires. I had to use 1/4" spacers on the wheels because the tires would barley rub the bed side on turns. the truck rode really good. The CE kit was real easy to install. With a 59 1/2" rear you will probably have to use wheels that are the same width as the stock ones.
