35 Ford wire wheel info needed...
Discussion in 'The Hokey Ass Message Board' started by poboyross, May 2, 2011.
  1. poboyross
    poboyross
    from West TN
    I'm about to embark upon my first Model A build, and I'm getting a set of 35 wire wheels from Dirtiest Devil here on the HAMB. I want to do bigs and littles like the Lieb Roadster (or a reasonable facsimile thereof) or the Bishop/Tardel roadster. What are the tire specs I should be looking for? I need a more economical option like Firestones...
    The Lieb Roadster:
    Bishop/Tardel:
  2. chrisntx
    chrisntx
    from Texas .
    7.50 on back, 6.00 on front
  3. poboyross
    poboyross
    from West TN
    Ok, so that's the width (THANKS!)....any idea what the full specs would be for the Firestones I'd be looking for?
  4. chaddilac
    chaddilac
    7.50x16 and 6.00x16.. pretty simple... it was much easier back in the day! :D
  5. poboyross
    poboyross
    from West TN
    Thanks!! Yeah, easy answer to a stupid question. I've got too many numbers and designations floating in my head from my modern cars and my 50 Chevy XP
  6. junk yard kid
    junk yard kid
    Now i dont know for sure, but it says you need a wider wheel than what a 35 wire is. But thats what i got on mine, 7.50 and 6.00.
  7. DirtyWoody28
    DirtyWoody28
    7.50 and 5.50/5.75 i think the 6s look to big
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  8. chaddilac
    chaddilac
    I agree... I'm running 7.50s & 5.50s I like the smaller tire up front, but not the 4.50s... too small imo!
  9. lowsquire
    lowsquire
    from Austin, TX
    Ive just mounted a set of 5.50 x16s and 7.00 x16s Firestones on 35 wires, and they are perfect. I much prefer 700x16s to 7.50s in firestones..the height difference is tiny (about 3/8") and the 700s have a wider tread with more grooves. 7.50s are really a little too bulgy looking on a stock width wire wheel. 700s are a perfect looking rear size for these wheels.
  10. what he said ^
  11. slddnmatt
    slddnmatt
    i believe these were 6.00 and 7.50's also..
  12. poboyross
    poboyross
    from West TN
    Can you guys toss up some photos (if you have them) with the tire specs? I was just looking at this post in the HAMB cl***ifieds...says he's running the following:
    http://www.jalopyjournal.com/forum/showthread.php?t=585459
    tires and wheels
    front- '35 or '36 ford 16" wires
    4:50/16 firestone biasply tires
    rear-'35 or 36 ford 16" wires
    700/16" firestone bias ply tires
  13. ibcalaveras
    ibcalaveras
    I'm running the same on my Roadster. Works for me...
  14. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Perfect '40's combo is 7.00x16's out back and 6.00x16's up front. That was the most common hot rod tire in the 40's and looks great today. If it were a 50's build I would shoot for a 7.50x16 out back and either a 5.50 or 6.00 up front.
    The reason why I like 6.00's up front is that it visually shortens the wheel base and makes the car look more proportional. The 7.00 are a bit wider out back and they look great on wires.
  15. Saxon
    Saxon
    from MN
    6.5 firestone tread pattern is different then the 7 - 7.5. 6.0 will match the 7.5. Unless they changed that in the last 6 months or so.
    35 wires are 3.5" wide. 7-7.60 suggest 4" plus. Must people run them without any problems ever.
  16. poboyross
    poboyross
    from West TN
    Cool...I was just wondering what 7x 16's out back and 5.5x16's up front looked on a 28/29 roadster or coupe.
  17. 3wLarry
    3wLarry
    from Owasso, Ok
    hang on ...I got one here somewhere...gimme a minute...
    ok, this is what I'm driving to straykat 500...my buddies '28. 5.50x16 fronts...7.50x16 rears.
    5.50's are 27.5 inches tall...6.00's are 28 inches tall...7.50's are 31 inches tall...7.00's are 30 inches tall....
    kidcampbell71 likes this.
  18. Mart
    Mart
    My Sedan is sitting on 7:50:16 and 6.00:16 blackwall Firestones on 35 wires.
    Mart.
  19. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    It should be noted that the size of 7.50's depends on the make of the tire. My 7.50's on the back of my '35 are 32.20" tall which it over an inch taller then the Firestones.
  20. MATACONCEPTS
    MATACONCEPTS
  21. poboyross
    poboyross
    from West TN
    That's AWESOME looking, man. I like the 7.5's you've got in the back. Would you get a similar look/effect by running 7's in the back, 4.5/4.75's in the front? I only ask because I have one 16x7 available to me...I'd just have to get a mate for it for the back, then get the fronts.
  22. poboyross
    poboyross
    from West TN
    Bad link, meng.
  23. swifty
    swifty
    Be careful with the 450/475-16 if you have a heavy engine as the load rating on them is only 660 lbs at 30psi whereas the 500/525-16 have a load rating of 1070lbs at 32psi. If you are running a Hemi, Nailhead or even a flattie you need to consider this.
    600-16 have a load rating of 1400 at 32psi so they're OK for anything.
  24. poboyross
    poboyross
    from West TN
    I'll be running a (GASP) 305/PG combo for awhile...probably swapping out for a power pack 283 once I get around to rebuilding it.
  25. model.A.keith
    model.A.keith
    6.50 rears 6.00 fronts................
  26. goetzcr
    goetzcr
    I'm not sure if you've resolved this already... You mentioned the Lieb roadster (one of my personal favorites); from the streetrodder article: "The 17-inch wheels (4.5 and 5.5 inchers) are a combination of parts (Kelsey Hayes hubs, hoops from Coker) and ***embled by the Wheel Smith. They're wrapped in Excelsior 5.50 and 7.50 rubber."
    http://www.streetrodderweb.com/feat..._model_a_roadster/photo_01.html#ixzz1TQAhwPF2
  27. gas pumper
    gas pumper
    Poboy, Are you gonna drive the car in NJ?
    600 on the front is way better than a 500. The difference on my T is nite and day. ride and handling. Had the 5's now have 6's.
    and 650 is the last 4 ply tire in the sizes, for Firestones, anyway. The 6 plies will ride harder and get hotter.
    Model.A.keith, That A is right!!
  28. rusthaug
    rusthaug
    Here is my 29, 7.50 16 rear and 5,50 18 front..
      46.7 KB
      68 KB
