35 Wires
Discussion in 'The Hokey Ass Message Board' started by dakotajayne, Jun 19, 2008.
  1. dakotajayne
    dakotajayne
    from 3c1
    Im Using '35 Wire Wheels On My New '27 Lakester. Im Concerned About Their Strength. Has Anybody Had Trouble At The 300 Hp Level And Skinny 700-16 Firestones? Tx
  2. tommy
    tommy
    No the tires will fry before you hurt the wheels.
  3. brokenspoke
    brokenspoke
  4. 2-TONED
    2-TONED
    find the ad Henry ford had 'i think in 33' where he had a whole car hung (in the air) from one of his wire wheels.
  5. PASTDUEBILL
    PASTDUEBILL
    Keep um tight. Mine will sometimes loosen. Don't know why.
  6. Andy
    Andy
    Are you running the on 40-48 drums? Do you have the support rings? I sell them cheap.
  7. jambottle
    jambottle
    make sure you run the special spacers behind the wheels, if you are not running the original 35 rear drums.
  8. jambottle
    jambottle
    that`s them. andy was posting the same time i was.
  9. Buzznut
    Buzznut
    I don't think you could run them at Bonneville... and I HAVE heard of guys spinning the outer rings right off the hub and wires going everywhere. When you say Lakester are you talking for race or land speed? If so, I personally would shy away from wires... if you want a similar look try artillery wheels...stronger, nostalgic and still cool.
  10. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    From just one spoke
  11. 2-TONED
    2-TONED
    not one spoke i dont think.:eek:
    its a 33 or 34 ford coupe hanging in a building on display by a wire wheel showing the strength of the ford wire wheels. --- someone must have the ad somewhere. i have a few of those ads at home ill have to look for them sometime. ------ the wheels are strong!
  12. Buzznut
    Buzznut
    Doesn't matter HOW strong they are...regulations are regulations when it comes to racing. Spokes have the potential for causing disaster... I just don't think you'll be able to race on them in many places, if at all.
  13. Kirk Hanning
    Kirk Hanning
    Not to hijack this thread.....How much if any are Kelsey Hayes accesory 40 "bent" spoke wheels stronger than a stock spoke?
  14. G V Gordon
    G V Gordon
    from Enid OK
    Like has been mentioned, with a 7:00 tire you are not going to have any trouble This is ***uming your 73 year old rims are in good shape to begin with.
    If you had widened the rim, added offset, installed fat sticky tires, those would all add to the possibility of wheel failure.
    Much like the drum brake debate, your limiting factor is the tire patch and traction.
    BTW I have the exact set up you are talking about on my '27 with a 348 W motor.
  15. dakotajayne
    dakotajayne
    from 3c1
    Tx To Every Body For Your Input! I Havent Heard About The Support Rings. Plz Tell Me More. Dakotajayme
  16. weemark
    weemark
    from scotland
  17. While it is true that SCTA will not allow wire wheels some venues have no such restrictions. We just ran my lakes modified at the Antique Nationals with KH wires. Rears are widened 1 1/2 " on the inside. If the car is light,1500 Lb. or so it will just spin I don't know the torque or HP on my engine, it is a model "B" with a 2 port conversion, probably less than 150 HP but has a lot of torque. With 5.30's in the rear end it will break loose with 2 nd gear starts.
  18. J Man
    J Man
    from Angola, IN
    The Hot Rod Company aka Sidevalce sell the Tardel rings for the wheels.
  19. gas pumper
    gas pumper
    I with the gang here, I run them on a 1700 lb T w/283 and a T-5, banjo w/4.11's. The tires spin real easy. 600x16 Firestone. I figure I can't hurt the rims or the rear end.
    Frank
