Technical 350 crate pushrods
Discussion in 'The Hokey Ass Message Board' started by Dino 64, Mar 18, 2022.
  1. Dino 64
    Dino 64
    from Virginia
    So I just started up the coupe today for the first time this season, and a loud ticking noise from the p***enger side valve train. At first I thought it might be a stuck lifter. When I pulled the valve cover, one of the pushrods was gone ! Looking down into the valley, I saw it lying in the valley, obviously bent. Turns out the mounting bolt for my Moon breather hit the rocker arm. How it ended up down there is a mystery to me.
    Anyway, I’m gonna pull the intake tomorrow and see what else might have been damaged.
    My question is, what size pushrods fit this engine. It’s a crate 290 hp. Serial # 12499529z. Can’t seem to find the part number for a pushrod. Any help is much appreciated.
    Thanks :mad:;) 18E3A34F-CEA3-4AC3-A5F3-4C3A8A5E061A.jpeg E77B28AF-CF0F-4D8E-81F6-4C4B534843BD.jpeg
    Deuces, mad mikey and Just Gary like this.
  2. saltflats
    saltflats
    from Missouri
    Just pull one of the others and measure it.
  3. Dino 64
    Dino 64
    from Virginia
    Was hoping to avoid that but I guess that’s the easiest after all.
    Thanks
    mad mikey likes this.
  4. 1934coupe
    1934coupe
    I think you will find they are 3/8". But crate motors may be a little smaller metric size.
    Pat
    Dino 64 likes this.
  5. Fordors
    Fordors
    A SBC flat tappet cam will use 7.800 long pushrods and OEM Chevy roller cams use 7.200. Your 350/290 has a flat tappet cam.
  6. Dino 64
    Dino 64
    from Virginia
    Thanks, haven’t been able to track done a part number or specs anywhere.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    If the lifter is still in its bore, I would just fish that pushrod out with a magnet and replace it. can't think of a good reason to pull the intake....
  8. Dino 64
    Dino 64
    from Virginia
    Ha ! Been trying to get it out but so far haven’t tried a magnetic probe yet. Thanks, I’ll try that tomorrow, however I’m concerned other damage might have been done. Might pull the intake to be sure
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    can't imagine what else could happen... the pushrod took all the damage when it bent I would think...
  10. Dino 64
    Dino 64
    from Virginia
    Yes, it’s bent, I agree
    Thanks
    mad mikey and Moriarity like this.
  11. Go to Rock Auto,and check several different late 70"s- early 80"s 350 engines for push rod. I bet you find they used one part number for many years.
    Truck64, Truckdoctor Andy and Dino 64 like this.
  12. Dino 64
    Dino 64
    from Virginia
    You know, it’s the ‘what model is it from, year etc’ is what you get at auto parts places around here unfortunately
  13. Fordors
    Fordors
    Just ask for a 1980 350 Chevy pushrod.
  14. Dino 64
    Dino 64
    from Virginia
    Hey’ Thanks, I’ll try that ;)
  15. ClayMart
    ClayMart
    Dino 64 likes this.
  16. chop&drop
    chop&drop
    I have the spec sheets for that engine. The Chevrolet part number is 14095256. Available lots of places.
  17. From looking at the first pic,,,,the lifter is still in the bore .
    There is a very large access window in the head,,,,,,you can see clearly down in there .
    Buy a telescopic magnet,,,,,,that pushrod will come right out through the window .
    While that valve cover is off,,,,,,loosen the rocker beside it,,,,and remove that pushrod .
    There is your example for the length measurement .
    To aid in adjusting the rockers back,,,,,,,,count how many full revolutions you turn the nut .
    Then you know where to put it back to ,,,,,easy as pie !
    Everything should be fine,,,,,by the way,,,,,,,use that same procedure to adjust the rocker with new pushrod too .
    Tommy
  18. Dino 64
    Dino 64
    from Virginia
    Thanks for all the advice everyone
    Appreciate the help :)
    lothiandon1940 and Just Gary like this.
  19. indyjps
    indyjps
    How about a full new set - sbc pushrods are about as inexpensive as parts get. The ones in there can't be great. o_O
    How'd it get bent? May still have other issues with lifter or valvetrain.
    Dino 64 likes this.
  20. Dino 64
    Dino 64
    from Virginia
    Earlier post, rocker hit a bolt head holding the Moon breather.
    Thanks
    lothiandon1940, indyjps and Moriarity like this.
  21. ClayMart
    ClayMart
    Click the link below to find the build sheet of component parts for your engine ***embly, and a few other Chevy crate engines.
    https://paceperformance.com/p-3982-gm-crate-engine-parts-list.html
    Click the link to download the file for your specific engine. The slightly strange part is that the info is laid out as a spreadsheet (.xls) file instead of the more commonly used .pdf format. If you're using Windows and have Office installed you're good to go. If not, you can probably open it with XLS Viewer which you may already have depending on which version of Windows you're using. Here's a link to download a free copy of XLS Viewer if needed.
    https://www.microsoft.com/en-us/p/xls-viewer-free/9nblggh6hbf5?activetab=pivot:overviewtab
    You can also use LibreOffice, a freeware version of Microsoft Office that might have already been installed on your computer.
    Dino 64 likes this.
  22. Dino 64
    Dino 64
    from Virginia
    Thank you very much !! I couldn’t find that online. I’m going to try to fish it out today. But the info you sent is really what I need.
    Thanks again, much appreciated
    Just Gary and harpo1313 like this.
  23. mad mikey
    mad mikey
    Call Summit, they will have the pushrods you need . You will most likely have to buy a set but it's not a lot of $. I would check that rocker arm as well.
  24. Dino 64
    Dino 64
    from Virginia
    Taking the rocker off this morning, after a I get a magnetic probe, I’ll check it !
    Thanks
    Just Gary and mad mikey like this.
  25. mad mikey
    mad mikey
    Dino, probably the only damage is the push rod, the little chevys are pretty tough. Keep us posted.:)
  26. Dino 64
    Dino 64
    from Virginia
    Thanks, I will. Got to get this taken care of, Jalopyrama is soon !! :):)
  27. Dino 64 likes this.
  28. Dino 64
    Dino 64
    from Virginia
    Thanks the post by @Calymart has that part number but I appreciate your post too !!
    mad mikey and lothiandon1940 like this.
  29. alanp561
    alanp561
    Jegs # 555-20210
    mad mikey, lothiandon1940 and Dino 64 like this.
  30. Fordors
    Fordors
    I realize this a new crate engine but if I was in this situation I’d buy one new p/r from Advance Auto Parts, they list them at $1.99 each. They could be a low volume item being closed out from their inventory. Genuine GM parts average $14 or so for one pushrod, sounds ridiculous to me.
    I would even put a used one in as long as it was 7.800, the ends were smooth and it was clean inside. JMO.
    alanp561, mad mikey, pprather and 5 others like this.
