351 Cleveland.....????
Discussion in 'The Hokey Ass Message Board' started by ModelAMafia, Nov 11, 2008.
  1. hotroddon
    hotroddon
    I don't know why all you guys keep saying it's heavy. It only looks that way. Here are some real world comparison numbers:
    351C 550 LBS
    351W 525 LBS
    350 Chevy 575 LBS
    409 Chevy 685 LBS
    454 Chevy 685 LBS
    360 Mopar 560 LBS
    440 Mopar 670 LBS
    Now for the real porkers - Allison V12=1160 LBS and the Merlin is a whopping 1540 LBS
    for the light weights, 302 Ford = 460LBS and the champ is the 215 Aluminum Buick at 315!
    So the Cleveland is not overweight pig by any means!
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    That and the Shelbys never got 351C.
    Gotcha. Beautiful car, BTW. Context was lost from post #4 to now though, so an appropriate caption would've helped! :D
    Oh yeah, even '70 Shelbys used the 351W because they were all really left over '69s! :eek:
    No, but the 351M is (flame suit donned)
  3. hotroddon
    hotroddon
    The 351M/400M weigh 575 so still right there with the over rated SBC!
  4. Flat Ernie
    Flat Ernie
    Tech Editor
    Yes, but it is a pig with a reputation for throwing rods (that's what the flame suit was for!) :D <-- see, smiley = tongue-in-cheek
  5. repoguy
    repoguy
    Over rated?
    Is that why stroker sbc's practically dominate the local street drags?
    Because they're so over rated?
    That makes tons of sense.
  6. They dominate because there so cheap to build and easy to get the go fast parts for. You can make more horsepower with a Ford 302/351 but it will cost you more money.
    Well worth it I think, its about the same over here top build a serious 351 as 350, there are some monster 302 and 351 based cars running in the street dargs, some stroked and punched out up to 475ci!
  7. tjm73
    tjm73
    They also have a huge following because Chevy was good about having decent factory heads and making good power in stock form. Ford engines have always been saddled with sub-par heads. Any Ford engine of equal displacement to a Chevy engine will match or beat a Chevy of similar size.
    It has nothing to do with brand and everything to do with airflow. In many instances the Ford engines seem to have mechanicall advantages in power production. In othere's Chevy has the advantage.
    But in the early days, Chevy had the advantage fromthe factory and they have built a loyal following from that.
  8. repoguy
    repoguy
    I agree with both of you.
    I just think that any engine that can be built as cheaply as an sbc, and run as hard as a stacked sbc, and pretty much dominate the street drags can hardly be considered "over rated". There's a reason they're so common - and it isn't because they ****.
  9. JRRoberts
    JRRoberts
    from Madison WI
    Over rated, cheap or not...... I am pretty sure this thread was about the FORD Cleveland
  10. hotroddon
    hotroddon
    Never said they ****. I said they were over rated because so many seem to think they are the greastest V8 ever built. They are not. They are a great way to make cheap horsepower for sure and they certainly have a loyal following and there is nothing wrong with that, it's just that they are not the greastest thing since sliced bread that many seem to think. Not knocking them, just the folks that can't see past the alter of the bow tie.
    I'll take a 351C over a 350SBC any day. And as Dan Gurney once said "the small block Ford is the best V8 ever, just needs some cylinder heads" :eek:
    "Dominate the street drags"? Naw, 5.0 Mustangs have taken over that spot :D
  11. repoguy
    repoguy
    Yeah, I suppose you're right on that one.
  12. SOCAL PETE
    SOCAL PETE
    from Ramona CA
  13. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    Yep and thats why DG put in on their *** in the TRANS AM series with that BOSS 302 :D
  14. hotroddon
    hotroddon
    And then there was this!
  15. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    Thanks I just got wood at work......:eek:
  16. The Hop Walla
    The Hop Walla
    from Dallas
    351 Cleveland was THE hot mill when I was in high school (70s). They were plenty fast.
    dka
  17. hotroddon
    hotroddon
    I think this has just inspired me! I have a blown and injected Cleveland that was in the Anglia sitting in the garage wondering what to do with it. I'm thinking it might have to fall between the rails of the 32 coupe. What do you guys think?
  18. elcornus
    elcornus
    DO IT!!!!!!
    I LOVE CLEVELANDS!!!!!
    Here's mine, WC T-5 and a locked 4:11'ed 9" going into a '27 Dodge sedan
    Long live the cleveland!!!!
  19. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    You could always send it down here to SOCAL...a certain 37 needs a power plant...I'd treat it right...promise not to break it. :rolleyes:
  20. stealthcruiser
    stealthcruiser
    You won't do it!
  21. hotroddon
    hotroddon
    Is that a challenge?
  22. thall
    thall
    from nc
    were the timing sets from the factory in these 'retarded' a bit for emissions??
    I seem to recall that was one 'good' performance improvement....
    never checked it out though...
    I pulled one from a 44k mile torino wagon in 78 or so and never used it... it is around somewhere...
  23. Chevy's NASCAR motor has the distributor up front. But who the hell knows what kind of motor it is. A bunch of those 400M's wound up in airboats. For awhile that was the thing to have down in the Everglades.
  24. Weasel
    Weasel
    I call fake - looks like a Windsor to me - the Cleveland has the timing chain cover cast as part of the block. The Cleveland fuel pump mounts to this casting - not to the bolt on timing chain cover shown in your photo.
    Here's a couple more shots of the genuine XE Australian Cleveland block with Gurney Weslake heads. Waterpump is the Snow White shorty conversion, bolted to the cast with the block Cleveland timing chain cover.
  25. vicious
    vicious
    had a C in my 71 mustang
    was a dog until about 3.5 to 4K
    4K to 6K was a totally different car
    the few times i turned it faster than 6K i about had to have the seat surgically removed
  26. hotroddon
    hotroddon
    Not a fake anything - real life Gurney Eagle 302 - didn't claim it to be a Cleveland, just a Bad *** Ford
  27. spiffy1937
    spiffy1937
    from Florida
    One of the best running street engines I ever had was a 351C with the 2 barrel heads and an aluminum 4 barrel intake. The thing pulled hard all through the RPM's. I don't think they are ugly with the proper valve covers, etc just like any engine.
    Pretty sure this is a 351C in this '32, sure don't look bad.
  28. JRRoberts
    JRRoberts
    from Madison WI
    I actually really like the way that Clevelands look, especially when they have the flat valve covers.
  29. Flat Ernie
    Flat Ernie
    Tech Editor
    Wow - I've been out of the airboat scene for at least 10 years now, but in the '70s, 80s, & 90s - if you weren't running a no-**** aircraft engine, you ran Cadillac and Big Blocks. Seen a 500" Caddy swing a 76x76 prop in a gl*** hull!!
    Of course, this was before you had to run the exhaust out through the lower portion of the cage and all the other namby-pamby rules they've got now...
  30. Weasel
    Weasel
    I thought this thread was about Cleveland engines.
    BTW read the valve covers - it's W-E-S-L-A-K-E there is no T in Weslake.
