Up for your consideration is a 408w stroker motor. There is just under $12,000 invested in this engine. Im asking $6000 for the engine. This engine has been ran on a test stand for 30 minutes. This engine is estimated at 650-700hp. Please look closely at all the pics. You can clearly see this engine is new. The parts list for this engine are listed below. You will be getting this engine for less than the value of the parts to build it. Serious inquiries only. Please text or call 423-716-5234 AFR (air flow research) cyclinder heads. Part #1450 205cc heads 2.080 intake valve 1.600 exhaust valve Edelbrock RPM air gap intake part #7581 Eagle stroker kit part #435140006200 Eagle crank 4.00" stroke Eagle I-beam rods 6.200" Forged pistons 9.5:1 compression ratio MSD distributor part #85805 Edelbrock aluminum water pump ARP studs and bolts on the entire engine Aluminum fabricated valve covers Rare Holley CENTER SQUIRT 850 double pumper. Crane cams 1.6 roller rockers. Crane camshaft. (Im looking for my build sheet to get the cam specifics) Dual roller timing chain
