Hot Rods 351w Valve Adjustment
Discussion in 'The Hokey Ass Message Board' started by 52JimmyV, Feb 11, 2017.
  1. 52JimmyV
    52JimmyV
    So I got tired of googling and finding conflicting information. Can anyone tell me how to properly adjust these valves? 351w, I think it's off of a 84 bronco/truck.
    From what I gather, they are non-adjustable positive stop valves that need to be "set" as the following:
    1. Place cylinder 1 on tdc
    2. Tighten ALL valves at 18-23 lbs of torque
    3. That's it???
    I've worked on my chevy 350 for 20 years with the "regular" valve adjustment procedure. This is throwing me off.
    ANY ADVICE APPRECIATED before I fire up this baby. Thanks 20170211_051827.jpg
  2. You just torque them down. That's it. No procedure. Nice and easy, isn't it??
  3. fordf1trucknut
    fordf1trucknut
    Yup just torque down, unless you have the heads milled a lot then put shims under before ya torque them down.
  4. These are what is known as "non-adjustable rockers". Which means, you guessed it, there is NO ADJUSTMENT!!
  5. hotroddon
    hotroddon
    These guys are right - there is no adjustment necessary, or possible! Done
  6. s55mercury66
    s55mercury66
    from SW Wyoming
    Ford made different length pushrods for them. Something like .030, .060, .090 shorter ones if I remember correctly.
  7. falcongeorge
    falcongeorge
    from BC
    which, depending on your point of view is A) a real plus, or B) one of the things that makes Fords a royal PITA.:mad:
  8. rjones35
    rjones35
    Being not a Ford guy, and hopefully not too dumb sounding, does it matter where the pistons are if you're just tightening them all down to a certain torque anyway?
  9. s55mercury66
    s55mercury66
    from SW Wyoming
    As long as the cam is timed correctly, it makes no difference.
    falcongeorge likes this.
  10. henryj1951
    henryj1951
    from USA
    The carlot krook's would just fit FILL with Big sections of sponge under the Valve cover and sell it, that killed the clacking.
  11. Engine man
    Engine man
    from Wisconsin
    I advise you to lube the valve, rockers, fulcrums and push rods. It looks pretty dry. If it's a new build it could take some time to pump oil up the push rods and it will squeak badly before it gets there.
  12. And the pushrods look a little clogged, so running a wire through them with some solvent, blow drying them and then forcing some oil into them before installing would be smart, too.
  13. 4wd1936
    4wd1936
    from NY
    Everyone is right on, all excellent comments. The only fly in the ointment will be if you are running an aftermarket cam where the heel and ramp has been cut down to obtain the desired lift. Then you will need to change to an adjustable system similar to a Chevrolet. If not too radical you may be able to get away with locking rocker nuts and blanch ground washers under them. Good luck
  14. 52JimmyV
    52JimmyV
    Thank you everyone for the advice. It's a stock cam and not a fresh rebuild, but its been sitting there for years. I'll take your advice and clean and lube all the parts that I can. Thanks again
  15. George
    George
    run the oil pump before trying to crank it up.
