1952-59 Ford 352 in a 54?
Discussion in 'Off Topic Hot Rods & Customs' started by strayca631, Oct 8, 2012.
  1. strayca631
    strayca631
    from Norway
    Something funny happened today. I Was in the garage when a guy stopped by with a 352 with an auto Box out of his 57 Merc.... He was about to throw it away! So when I told him that I could use it in my '54 customline he let me have it ;-) Now to my questions... The engine was loosing some water, he thought it went out in the exhaust on the right side, probably on the 2 rear cylinders. Is this a common problem? Could it be a crack in the head or just a gasket? Next question: My car had a straight 6 and a manual box... Will the swap be straight forward or isn't it possible at all? I''ll be grateful for any answers, I know a lot of you have tons of knowledge on this cars...
  2. Ole don
    Ole don
    a 352 wouldn't be my choice to buy, but since it was free, I can see it installing itself late at night when you aren't looking. I would go through it to freshen things and run it on a stand before installing it.
  3. raceron1120
    raceron1120
    Not to take away from your original question but to ask one. Being a 352 in a '57 Merc?? 352s were intro'd in - I think - '59 so the engine wasn't original to that Mercury.
  4. streetdreams
    streetdreams
    '58 actually, along with the 332. Sure it ain't a 312 or 368 ?
  5. bondojunkie
    bondojunkie
    I thought Mercs and Edsels had different sized engines than fords (MEL's)? They all look like FE motors to me.
  6. strayca631
    strayca631
    from Norway
    Looks like you may have a point... looking at the engine in daylight makes me think its a MEL, possibly a 368.
    Well then, is it possible to put that in a 54?
  7. raceron1120
    raceron1120
    Is it possible to get a picture of it? That should help the experts make a positive identification
  8. strayca631
    strayca631
    from Norway
    I'll try to snap a couple of photos tonight...
  9. streetdreams
    streetdreams
    stray, 368 is the Lincoln Y-Block series, not the same as Ford Y block. MEL is different. Anything will fit in anything with a big enough hammer.
  10. Modest
    Modest
    from Loomis ca
    Shoehorn it in if ya dig it but I wouldn't get your hopes up too much about performance.they sound great in my opinion.
  11. merc-o-madness
    merc-o-madness
    not sure but if its the same as an FE engine it will work
  12. crayhill
    crayhill
    From my experience all the FE 352s are stamped '352' on the top right corner but they could in fact be a 332, 352, 360, 390 or otherwise. I currently have a 352 stamped block but it is in fact a 390 ci motor. Since you have the motor out of the car, you could yank the oil pan and check the crankshaft for an identification stamp and compare it to the ones at this link. - http://www.fordification.com/tech/castingnumbers-FEcrank.htm-
    Also, if you end up pulling the heads to fix the leak, you can measure the cylinder and determine the overall cubic inches using this formula -(Bore X Bore X 0.785 X Stroke X Number of Cylinders = CID) Bore = cylinder width, Stroke = Distance from cylinder lowest point to highest point
    http://www.erareplicas.com/427man/engine/partnums.htm
  13. Nite Owl
    Nite Owl
    Take a look at the heads and check the valve covers. If the valve covers cover a good portion of the intake, it's an FE. Like crayhill says, it could be anything from a 332 to a 428 if it's an FE.
  14. strayca631
    strayca631
    from Norway
  15. strayca631
    strayca631
    from Norway
    I'm pretty convinced now, this must be a Lincoln Y-block 368! It's the right engine for the Mercury it came out of, and the block has long skirts below the crank...
  16. crayhill
    crayhill
    Hard to tell from that pic, but I have never seen that bulky style of water pump on an FE 352. I would guess this is a Y-block but I have no experience with them so someone else can make that call.
  17. strayca631
    strayca631
    from Norway
    The FE got the distributor in front. This one's got it in the rear end of the intake, so it's not an FE.
  18. streetdreams
    streetdreams
    That's a Ford Y-block. Get a part number off the block and/or intake and we can tell you what it most likely is.
  19. strayca631
    strayca631
    from Norway
    Found the number on the intake; ECZ-9425-B
  20. raceron1120
    raceron1120
    Lucky you - it's a 312
  21. streetdreams
    streetdreams
    The intake is good. Check the side of the block for ECZ
  22. strayca631
    strayca631
    from Norway
    Is that an easy fit? Remember it came out of the factory with a straight 6...what mounts to use?
  23. streetdreams
    streetdreams
    They also came with 239 Y block V8s. The correct V8 mounts should do it. Updating those cars to a 292 or 312 was a real common swap.
  24. strayca631
    strayca631
    from Norway
    Thanks for good help. Tried to find casting numbers on the block today, but I couldn't find any. Do I need to change the prop shaft and gearbox mounts as I go from manual to automatic?
  25. streetdreams
    streetdreams
    The block casting numbers are on the side, above the pan rail. Should see ECZ if 312.
  26. raceron1120
    raceron1120
  27. JeffB2
    JeffB2
    from Phoenix,AZ
    The drive shaft is the same,what you may not like is the rear end ratio that your six has (3:90)with a V8 and automatic it will be turning some revs when you are highway cruising.
  28. strayca631
    strayca631
    from Norway
    I don't know what gears I have, since my rear axle broke the first summer, and I got an axle out a 55, but I don't know if it was a 6 or v8 car...
  29. strayca631
    strayca631
    from Norway
    Found the casting number on the block today, and YES it's an ECZ-A ;-)
  30. Ole don
    Ole don
    If it still has the 57 heads, they are the best ever cast for that engine. Take good care of them. In the past three years, aluminum have been available.
