Projects 36 coupe upgrades
Discussion in 'The Hokey Ass Message Board' started by hot-rod roadster, Jan 9, 2014.
  1. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Time to make the 36 a little more road trip friendly. Before the purists start complaining about this let me say that I loved driving this car with the Zeypher geared 39 box and banjo rear and it still seems to all work perfect but every time i set out on a road trip I find myself wondering what kind of problems I might run into before or if I make it back. Especially driving to racing at and driving home from the HAMB drags. How much abuse can 75 year old parts take? So enlisting the help of my friend Dave (RoadBurner1) who wants all the 39 stuff to build a T hotrod (which made for a perfect trade) and my Pal Gary at Cornhusker Rod&Custom with parts suggestions and direction we got started.
    Replacing the 39 gear box with T-5 5 speed box and short throw Hurst shifter (With long cl***ic looking shift handle). Also removed and replaced the 39 banjo and torque tube with an all new Johns 4.11 geared big bearing,31 spline 9" rear end and new brakes (so impressed with Johns quality and complete ***embled brakes ready to bolt on..So Nice) Pete and Jakes ladder bars and new dual resevoir master cylinder.
    To retain the 39 pedal set up we left the SBC to 39 box adapter and added a early ford to chevy trans adapter on back of it. then the new T5. Everything so far has seemed to go together pretty good with some fabrication needed. (split wishbones and remove part of 36 X member to add new trans mount) a new clutch/pressure plate and pilot bearing also required and new driveshaft.
    Still waiting on a few parts to finish it up but really happy with the progress so far. Also planning on a new exhaust front to back.
    Other than the improvements this should make to driving the car, there will be no obvious changes to its overall appearance and there are no plans TO EVER change the great natural patina this car has. Please don't ask when or what color Im going to paint it. This car is DONE!
  2. clips221
    clips221
    looking good.
  3. nice work , i think that will be a great improvement
    taking that stock crossmember saddle out with the body on is a pain , isn't it? done that a few times
  4. Brandi
    Brandi
    Patina. Like the burn marks on that one hood side. :)
  5. scrap metal 48
    scrap metal 48
    Very cool coupe.. I think your updates will make it much more enjoyable to drive and it sounds like that's what you like to do.. Did I say, cool coupe???
  6. Phil 41 Chevy
    Phil 41 Chevy
    only making it better.
  7. Paul
    Paul
    Editor
    "this car is done"
    yeah right :rolleyes:
  8. luckys8ba
    luckys8ba
    Damn,I love that car!
  9. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Nothing says hotrod like a little burn
  10. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    HaHaHa...Well its real close
    Thanks !!!
  11. hiboy32
    hiboy32
    from Omaha, NE
    I love that car. With these updates I hope to see it on the road more. I also love that kept the rear spring, means a lot
  12. Dooley
    Dooley
    from Buffalo NY
    I was going to ask how difficult that was, have throught about doing it but it seems like a pain....
  13. Phil 41 Chevy
    Phil 41 Chevy
    Reminds me alot of my 35. Get it to where you can drive it and leave the rest alone.
  14. go-twichy
    go-twichy
    36's came after the 35's. look it up.
  15. rob lee
    rob lee
    from omaha,ne
    Nice man,you know i'm not gonna give ya **** about the t5. 90-95 down the road hell ya
  16. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    I knew you'd get it Rob. Its cause of friends like you, JHO and Malcolm that this had to be done. Got tired of falling behind and not being able to catch up
  17. Rocky
    Rocky
    Classified Editor
    A great upgrade, Gary. I plan to use my T-5 in my 34 coupe project. I believe if rodders back in the 40's-50's would have had access to cheap, easy overdrives in their old fords, they'd have used them. Also, they didn't have the straight, modern, wide highways we drive on these days. 45-55 mph roads of the 40's-50's didn't require anything more than 3.78 gearing with a non-O.D. transmission.
    We're blowing down the interstates at 70-75 in our 70-80 year old fords just to keep from getting run over in today's traffic.
  18. Malcolm
    Malcolm
    from Nebraska
    Great improvements... and cool to have Davey working on it, too. I love that car.
    When are you doing a Mustang II up front? :)
    Malcolm
  19. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Quit it
  20. Phil 41 Chevy
    Phil 41 Chevy
    You are sure smart!
  21. RoadBurner1
    RoadBurner1
    from Nebraska
    Grinder, cut off wheel, torch, drill.....and a squirt bottle of water :D
  22. hiboy32
    hiboy32
    from Omaha, NE
    And when was the last time he posted
  23. RoadBurner1
    RoadBurner1
    from Nebraska
    Hey now....it hasn't been that long has it? See ya at the Rev show wednesday???
  24. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Dave fab'd up a whole new floor tunnel cover. E-brake and shifter in. Just finishing up some new dual reservoir master cylinder stuff and its about done. Gary
  25. cvstl
    cvstl
    from StL MO
    Nice tunnel!
  26. chinarus
    chinarus
    from Georgia
    Great idea on the eBrake mounting bracket
  27. ryno
    ryno
    i think he said something about corvette stuff..
    glad to see this getting done gary.
  28. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Geeeeeze you drive a hotrod your whole life, take a Vette out one time and...
    HaHaHa good to hear from you anyway. Thanks
  29. ryno
    ryno
    im just a jelious ***hole. both cars are beautiful, as everything you build.
  30. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Aaaaaannnd its back on the ground. Gary
