Technical 36 ford 4 speed?
Discussion in 'The Hokey Ass Message Board' started by bolsa boy, Apr 3, 2015.
  1. bolsa boy
    bolsa boy
    Is anybody running a T-10 behind a SBC in their 35-36 ford? I picked one up and would like to replace the 350 automatic with it but would like to know what complications I may run into. If any.
  2. alchemy
    alchemy
    I have a Muncie behind a flathead in a '40, which is similar but kinda not. Major thing you'll run into is a need for more clearance for the shifter. I had to notch the X member in that area and box it back in. Also, depends what pedal setup you are using, but you might need to do some fancy fab for that as well. I have a '39 pedal set in mine.
  3. bolsa boy
    bolsa boy
  4. joel
    joel
  5. I'm running one behind a 307 Chevy in my '38 Ford pickup, very similar frame to your '35-'36. I originally planned to run a Turbo 350 so bought the Ch***is Engineering kit and split the wishbone and opened up the X member to clear the tail of the transmission. The T-5 is longer, and the mount is further back, so had to redrill the holes for the rear trans mount on the bottom plate of the X member kit. Used a bellhousing from a '76 Chevy pickup, handing pedal ***embly from '52-'56 Ford car, clutch uses a master and slave from a mid '70s Mazda/Ford Courier to work the clutch fork that came with the bellhousing.
  6. bolsa boy
    bolsa boy
    Would you have pictures of your clutch ***embly? is it below the floor? Or firewall mounted?
  7. alchemy
    alchemy
    The notch was probably four inches wide by ten inches long. It's been years since I've been under there and it's hard to remember exactly. I built a rod to connect to the throwout arm.
  8. I have a Muncie behind a Olds Rocket in my '36. As mentioned, I had to cut quite a bit for the shifter. Here's a pic of the X-member area and one of my clutch linkage (using '39 pedals too)...
  9. bolsa boy
    bolsa boy
  10. lowcoe
    lowcoe
    I have a 700 r4 ready to go but driving my 56 chev w 283 and t 10 has me having second thoughts....
  11. Deuce Lover
    Deuce Lover
    Here is what I did in my old 36 coupe.I wanted to retain the 39 pedal ***y and replaced the pulled the Flathead in favor of a SBC so used a SBC to 39 trans adapter,then the Speedway T5 to flathead adapter.Had to use the early Chev flywheel which the Flathead pp bolted right on.Had to use the 55-57 Chev starter also.The trans is actually a S15 from a 93 GMC.It has the Ford pattern so I had to get the Wilcap plate to get it to work.Biggest problem for me was the pilot bushing.Had to have a new bronze one made since the input shaft of the trans reach was 3/4" short.What I did was complicated but it worked.
  12. lowcoe
    lowcoe
    Looks like the straight axle is still in there and the firewall is not cut. What kind of motor mounts did you use? My SBC oil pan is banging into the cross member.....
