Technical 36 Ford Build
Discussion in 'The Hokey Ass Message Board' started by rackets351, Jun 12, 2014.
  1. rackets351
    rackets351
    can anyone tell me the distance from the center bearing cap to end of travel on a C6 ****** slip yoke. Reason for asking is that I am trying to ensure I'll have at least 1" play in the drive shaft. Here is what I am working with, distance from end of ****** housing to rear end yoke is 43.5". I have a drive shaft that is 40.5" inches between bearing caps. I have a 1.5" stick-out of the shaft in the ******. Will a standard slip joint work for me or will I need something all together different.
  2. King ford
    King ford
    from 08302
    Dude stick the yoke in all the way ,pull it out one inch and measure center of yoke hole to center of rear axle u joint hole and that's how long the drive shaft needs to be good luck!
  3. rackets351
    rackets351
    Dude, i don't have a slip yoke, thus the question. Was hoping someone would have known what that distance is. Thanks anyway
