Projects 36 Ford coupe 5w reference needed
Discussion in 'Traditional Hot Rods' started by Boxcar's 1928, Jul 13, 2023.
  1. Boxcar's 1928
    Boxcar's 1928
    In need of a 35-36 5w coupe measured reference.
    Attempting to establish this replacement b piller. Need measurement pulled 1in below jamb bumper pad (hooking the inside step as shown) to the opposite b pillar step 1" below same point. Unfortunately my p***enger side is not much help as its floating. Thank you for reading. 20230712_173442.jpg 20230712_173430.jpg 20230712_173537.jpg 20230712_194407.jpg
  2. Tim
    Tim
    from KCMO
    So your wanting a measurement from the drivers side to the p***enger side at that point , correct?
    Boxcar's 1928 likes this.
  3. Boxcar's 1928
    Boxcar's 1928
    Yesser...please
    And if I were pushing my luck a bit. I'd ask about the inside A pillar measurement from right to left (as shown)
    Tim likes this.
  4. Boxcar's 1928
    Boxcar's 1928
  5. Boxcar's 1928
    Boxcar's 1928
    Any 35-36 body guys using 39 or 40 frames have any lessons learned to p***...just wondering
  6. 36ford40
    36ford40
    My 36 5W is in storage at the moment, I will try to get the measurement today and post later.
  7. Boxcar's 1928
    Boxcar's 1928
    Thanks sir
  8. 36ford40
    36ford40
    Sorry for the delay. On my 36 measuring the A pillar below the dash inside at the tack strip at the beltline=43 1/4"
    B pillar inside tack strip to tack strip at the beltline 53 3/8", at the floor level 6 " up [tunnel height] 53 3/8" tack strip to tack strip. My car had the floor replaced and some work to the door jambs but all back to factory specs or as close as possible. Hope that helps. Hotrod
  9. Boxcar's 1928
    Boxcar's 1928
    Yesser that helps alot!!! Sending you a PM.
    36ford40 likes this.
  10. Boxcar's 1928
    Boxcar's 1928
    Looks like I need to rebuild my A pillars. The inner face that ****s to the door. It's rotted and rippled.
    Looking for a front on and side shot of both top and bottom hinge points to use as a reference. Also....being without hinges...could someone p*** me the height of the (A piller side hinge) so I can ensure to get the p***ageway right.
    Thanks 20230716_104252.jpg 20230716_104303.jpg 20230716_104319.jpg 20230716_104327.jpg Thanks
  11. wheeldog57
    wheeldog57
    Looks like a M***achusetts car, uggh! But so much fun fabricating and welding it back together. Good luck and keep us in the loop
  12. Boxcar's 1928
    Boxcar's 1928
    Getting work done... Grafting in a 36 Sedan B pillar into a coupe.
    Illustrious Hector likes this.
  13. Boxcar's 1928
    Boxcar's 1928
    Does anyone happen to have a shot of how the a pillar relates to the positioning of the rockers? I'm looking for something to guide me in fabbing the cowl feet and I have to rebuild the a piller and needing to determine if that pillar structure extends down lower that the top of the framerail. My car is a little rough to determine this.
    R/
    Larry
  14. choptop40
    choptop40
    Thats a heck of a save and talent you have there...reminds me of my early years on rusty crusty and thats how you learn this stuff..no textbook will do it
  15. Boxcar's 1928
    Boxcar's 1928
    Appreciate the kind words. I'm in over my head on this one but hopefully too stupid to quit. Forced learning!
    brEad likes this.
  16. 36ford40
    36ford40
    Try the EMS website they may have a diagram and/or stampings. The Wescott website had a drawing of the frame dimensions as well as the body drawing if I recall. Let me know if I can help. Hotrod
  17. Boxcar's 1928
    Boxcar's 1928
    20230726_201648.jpg Moving right along with these diy a pillars. Still could use some reference pics to see where it fits relative to the frame. Offset from the frame. Frame bolt location from the a pillar
  18. Boxcar's 1928
    Boxcar's 1928
    Kinda stuck at the moment.... by going off the original I thought there was a jog on the original a pillar so I put one in the replacement one I'm fabbing up (see pics). I'm not sure if it needs to be there Or if this side remains flat....thus creating a pocket the hinge slips into....pretty sure the piller hinge piece slips in a slot vs surface mount....but I have yet to confirm that. Any pic references to 35-36 hinge areas would be appreciated. Looking at the drivers side....it appears there's a slot positioned on the jamb step and I also see no indication of a deliberate step pressed into the aft side surface of the a pillar...pics below of the d side.
  19. Boxcar's 1928
    Boxcar's 1928
    Finally pulled together enough info (thanks HAMB) to attempt to square up this heap. Next is the cutting and welding and fab...looking forward it.
    20231216_121312.jpg 20231212_195219.jpg 20231204_164640.jpg 20230419_151503.jpg
    brEad and Tim like this.
