Hey Kip.That notch in the frame looks really good.I really like what you are doing trying to keep the old untouched look.Great fabrication....Kenneth.
Next up is ****** mounts. I estimate I will need them to be about 2" taller so raising to the top of X member will give me most of that. A spacer will fine tune from there. .
With the pads tacked in place I formed a piece to go under the pad to tie the bottom back to the top piece. Then cleaned everything up and ready to start a little rust repair. .
Now because I dident want my frame to be weak because of patches I made boxing plates. And because I am a gluten for punishment I drilled them. .
It was time to put the reversed eye spring on the axle. Then put the rear end back in and install the newly built 39 trans with newer gear set. .
Now the 8rt is installed and checked for fit. The spacer's on the ****** mount's are fine tuned and she is ready to put the body back on. .
While I was working on the chasis I came upon a deal to good to p*** up so off to cali. to pick up some parts. .
I was thinking to maybe turn her into a three window. With a roof and doors it wouldent be that much work. .
So I set the body back on the frame. I had to trim the bottom of the fire wall a little after raising the engine and then everything went in to place. .e .
I knew that weather I changed the roof or not the floor needed to be repaired firs so I cut it out and got ready for the new floor. .
The radius rods were now to close to the floor for correct travel. So this will need to be addressed while installing new floor. I wanted to use the stock seat so raising the floor seemed a last resort. .
36 3 window roof and doors?? That's one heck off a find! I'd say go three window! You got the skills to do it.
Floors sitting in car. I ordered these floors when I started the car (thankfully) so that I would have them when needed. They were promised in 3 months. It took 4 more months of constant persuading to get them. Afterwards I learn that wait is sometimes several years and so I felt lucky. They are definitely beautiful floor panels and fit extreamly well. .
Thanks a lot. I was having a hard time deciding which way to go either 3 window or to figure out how to chop a 5 window and make it look *****en. I have seen a couple done right that nailed it.
