Technical '36 Ford Fordor / '53 Merc flathead compatability ?
Discussion in 'Traditional Hot Rods' started by Terranova, Oct 20, 2013.
  1. Terranova
    Terranova
    I have a stock '36 Fodor with a stock 21 stud motor in it. I have my eye on a '53 Merc in the area? On a 1-10 scale, one being "does itself" and ten being "don't do it" where does this swap fall?
    The '36 is slated for an everything but a body off rebuild with the motor being a key part.
    Thanks!
    T.
  2. HOTRODPRIMER
    HOTRODPRIMER
    Common practice,,no big deal. HRP
  3. Terranova
    Terranova
    Thanks!
  4. Straightpipes
    Straightpipes
    Actually there is quite a bit involved. That Merc just won't fit in there on it's own. You will need a bunch of parts and a search here will help you out.
    Briefly you'll need a 49-50 merc bellhousing as the 53 merc clutch linkage and bell are entirely different. You will need motor mount spacers. You will not have room for a fan as the 8BA type engine is quite a bit longer than your stock engine. ..........on and on.
    I ain't no expert but I've done a bunch of 8BA to early Ford conversions.
    I would take that engine down and convert it to 59A style cam, cover and distributor. It will make your life a whole lot easier.
