Technical 36 Ford headlight drop
Discussion in 'Traditional Hot Rods' started by kennj, Feb 9, 2022.
  1. kennj
    kennj
    Is there anyone that could do a headlight drop on 36 Ford original headlights
  2. chaddilac
    chaddilac
    There's a 36 build thread and the guy shows how he dropped his headlights.
    I can't seem to find it... was a guy in Oz or New Zealand. He had a long build thread. Maybe someone can post it.
    Basically he dropped the mounted up into the bucket farther so the buckets were closer to the fender.
  3. mrquickwhip
    mrquickwhip
    I think UK ford pilot had smaller headlamp stands which would bring the 36 headlamp down closer to the fender
  4. pprather
    pprather
  5. Happydaze
    Happydaze
    Whatever happened to Tech o Matic?
    Chris
  6. zzrodney
    zzrodney
    Here's how I made dropped headlight pedestals for my 37 Packard. Starting with 1/8" plate for the base and light mount, the filled in with 18ga steel sheet. I fitted 41 Plymouth park lenses for turn signals. Final result is a 3" drop.
  7. pprather
    pprather
  8. kennj
    kennj
  9. kennj
    kennj
    Any ideas where I could find these?
  10. sloppy jalopies
    sloppy jalopies
    '33 -'34 ford cars are shorter, but $
  11. I need to see more of this car !!!!!
    El Mirage Garage likes this.
  12. mrquickwhip
    mrquickwhip
    I will see if I can locate any over here and get back to you
  13. i.rant
    i.rant
    If there’s anyone out there that can retrieve an obscure thread on any subject faster than @pprather please step up.;):D
    pprather likes this.
  14. deuce1932
    deuce1932
    from Australia
    pilot stalks only work on 35 fords.. 36 headlight mount differently.
