36 ford pick up p/s
Discussion in 'The Hokey Ass Message Board' started by 35 phaeton, Sep 11, 2007.
  1. 35 phaeton
    35 phaeton
    from michigan
    I believe that the spindlesare the only differance. B
  2. chevy gasser51
    chevy gasser51
    What would you use to convert to power steering on this truck. It has the original front suspension. Who also has a kit or what to use for disc brake conversion on the front. Checked speedway no luck. ECI has brakes but they start a 1937 this truck is a 1936 what is the difference.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    Your light weight truck really doesnt need disc brakes to safely stop.
    Install 40 backing plates all around with a hydraulic system and you will be pleased.
    POWER STEERING????
    why???
    That truck does not need it at all.
    Rebuild your existing setup for a fraction of the cost.
    These fords handle great with the stock suspension.
  4. chevy gasser51
    chevy gasser51
    thanks just asking for a customer. He had asked if clould be done he is an older gentleman
