Projects 36 Ford Pickup cowl vent mechanism
Discussion in 'The Hokey Ass Message Board' started by A-Wall, Sep 14, 2008.
  1. A-Wall
    A-Wall
    the cowl vent ratchet arm and spring were missing on my 36 pickup. so then i found out that 33-34 p***enger car vent mechanism parts were interchangeable with 35-36 pickups or so i thought. i just bought the ratchet and spring at the kalamazoo show, get it home and i try to install it and it seems like the ratchet arm is too long, when i hook it on it hits the dash. i cant even see where to hook the spring to.
    does anyone have any pics or diagrams of how this should work?
    thanks
  2. the top of the spring should go into a little hole on the underside of the drip rail around the opening , and the other side to the end of the ratchet arm thing. i don't think you want 33-34 parts , on a friends `36 pickup i believe we used `35-`36 car stuff
  3. A-Wall
    A-Wall
  4. A-Wall
    A-Wall
    ok i got it to work, the spring end of the arm had to be shorted about 3/16" to clear the dash, the spring was very hard to get on and once i did get it on the vent was very hard to open and shut. so i heated the spring with a propane torch with tension on it until what i felt was the proper tension. now it work perfectly.
