Hot Rods 36 Ford Rear Bones under a deuce
Discussion in 'The Hokey Ass Message Board' started by krylon32, Nov 10, 2025.
  1. krylon32
    krylon32
    from Nebraska
    There's a guy on here trying to figure out how to make 36 bones clear the frame on a deuce. Many years ago a HAMBer solved that problem by blending 46-48 front bones into the forged portion of the 36 bones. The drop down portion of the front bones gave the necessary frame clearance. I give up, I've searched and can't come up with the article. ANYONE?
    Packrat and 51 mercules like this.
  2. alchemy
    alchemy
    Pretty sure it was Nealin’s RPU.
    Packrat likes this.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
  4. Andy
    Andy
    One way is to make the bones to axle mounts a little deeper. This moves the bones down and lowers the car.
  5. pprather
    pprather
    Like this?
    chrisp and HemiDeuce like this.
  6. RICH B
    RICH B
    Yep, gets a little close.
    dwollam likes this.
  7. uncle buck
    uncle buck
    IMG_1532.png Would the Carrillo Customs drop brackets help in this situation?
  8. krylon32
    krylon32
    from Nebraska
    The Carrillo parts are very nice/top of the line abit you may need a second mortgage to buy them. I used to have a pattern at the laser cutter for something similar that was much cheaper. Laser cutter retired/sold out and away went my patterns. I used them the few times I was building a vintage low rider ch***is.
  9. pprather
    pprather
  10. RICH B
    RICH B
    Wouldn't it just be easier to trim the tubes from the '36 wishbones and use '32-'34 wishbones which mount inboard. If you don't want weld mounts on the bells; '42-'48 wishbones are the right length, bolt up, and work too.
