Technical 36 ford spindles
Discussion in 'Traditional Hot Rods' started by kennj, Apr 13, 2017.
  1. kennj
    kennj
    could someone tell me the difference between 36 and 37 up ford spindles, seems all the adds for disc brakes are 37 up, the car has disc brakes from po so I am ***uming they are 37 or later but I want to replace them with a smaller setup to clear a 14" wheel.
    Thanks
  2. chopndrop
    chopndrop
    37-41 will be round back, 36-earlier will have straight sides with round top and bottom. 42-48 are square back
    adam401 likes this.
  3. adam401
    adam401
    Even though 37 - 41 axles are different from 36 axles I was always under the impression that the spindles were the same. Maybe not?
    I thought 35 and 36 had round back spindles
  4. adam401
    adam401
    Yeah Im stupid. I forgot about the 35 and 36 being round on top with flat sides.
  5. junkman8888
    junkman8888
    On the '36 and earlier spindles the bolt pattern for the backing plates is rectangular, on the later spindles, the bolt pattern is square. If you're wanting disk brakes that will accept a 14" wheel you may want to put that info in your ***le.
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    The difference in the 35 and 36 spindles is pretty much that the 36 uses the stub axle from the 37-up rather than the longer 28-35 early stub axle. That 36 spindle is not on ALL 36 but was a running change sometime during the production year.
