36 ford,what is this
Discussion in 'The Hokey Ass Message Board' started by hershambob, Sep 26, 2011.
  1. hershambob
    hershambob
    was checking out a 3w coupe a friend has just imported and we see this electrical part attached to the steering box,we have no idea what it does or why its there
  2. JimA
    JimA
    Light switch.
  3. flatjack
    flatjack
    Right, there is a rod attached to the horn ****on that goes down through the shaft and operates the switch.
  4. FANTM58
    FANTM58
    Mabet it cancels the turn signal ?
  5. squirrel
    good one!
  6. Heo2
    Heo2
    Hi low beam switch
  7. ems customer service
    it converts the electricity from left hand to right hand electricity
  8. 36tbird
    36tbird
    Whatever you do, do not touch that! It is imperative that you return that vehicle to its country of origin as soon as possible. It would be best if you do not discuss this matter with anyone further. Even though the car is 1936, I believe that part is still cl***ified. All I can tell you is that it is an early Enigma data transfer capsule.
  9. Dakota.za
    Dakota.za
    Not sure, but I think there's a split pin missing below the nut on the pitman-arm shaft..
  10. hershambob
    hershambob
    if none of you boys bid on stuff on ebay then we will happily take what you clearly dont want,[​IMG]
  11. fab32
    fab32
    Yup! Good 'ol Henry Ford electrical control switch. Operated by a rod down the center of the steering column.
    Frank
  12. 32SEDAN
    32SEDAN
    Could be the flux capacitor
  13. Boyd Wylie
    Boyd Wylie
    I've had some good smiles,with the answers here.:) Perhaps the easiest way to find out what it does,is the disconnect it,and see what stops working:confused:
  14. b-bob
    b-bob
    That sounds like something you would do Boyd!:D:D
  15. tubman
    tubman
    Boyd,
    Trust Fab32. He's right on the money and his answer is not a joke.
    Tubman
  16. I had a 36 that had a steering lock on the column.(looked factory). inserted a key, and flipped a toggle switch to lock. possible that it's part of the system? my mind is a little foggy as it was around 1970 when I owned the ford.
  17. kfleck
    kfleck
    from spokane
    JimA, Flatjack & Fab32 are all correct. it is the headlight and horn switch
    when you turn the plastic piece in the middle of the steering wheel it turns the headlight on and off and high beem. when you push the horn ****on the rod makes a conection and honks the horn. I dissasembled mine and turned it into a blinker switch in the center of my steering wheel.
  18. Bruce Lancaster
    Bruce Lancaster
  19. flatheadpete
    flatheadpete
    from Burton, MI
    Hope that smoke doesn't escape. It's a ***** to get back in!!
  20. Roupe
    Roupe
    Well I guess it didn't p*** the smoke test then.
  21. Fatrod
    Fatrod
    Confirmed as the horn and light switch...
  22. Bruce Lancaster
    Bruce Lancaster
    Without electricty down tere, it would be hard to ignite the gear oil leaking out of the steering box.
  23. tubman
    tubman
    I've had a bunch of early Fords, and amazingly, never had any problem with them. They sure seen to be a major problem waiting to happen when you consider the application.
  24. That looks like a very early style exaggertor, those things are as rare as ****, you should fetch big bucks for that puppy on Ebay!!
