Hot Rods 36 Ford Wiring question
Discussion in 'The Hokey Ass Message Board' started by Dervco, Dec 6, 2020.
  1. Dervco
    Dervco
    from Calgary
    My dad is working on his 36 ford (His first car) We put a newer flathead in it. We are considering converting to 12 volt mainly because it is easier to find 12 volt starters, generators, batteries etc. The issue we are facing is that the gauges are positive ground and the newer 12 volt stuff is negative ground. Is there a way to use the original gauges? Is there a work around? The car is not bone stock but built to drive and enjoy, Any suggestions would be welcome. Thanks in advance.
  2. goldmountain
    goldmountain
    The gauges work on negative ground.
    olscrounger likes this.
  3. rusty valley
    rusty valley
    if you go negative ground, reverse the wires on the amp meter
  4. Hotrodmyk
    Hotrodmyk
    The 6V starter works just fine on 12V.
