the problem is that the arm that comes off of the steering box can only go on two ways, it hits the pan. anyone have a solution? Thanks
You may need to use the 49-51 Merc rear sump oil pan for tie rod and drag link clearance. I am using one in my 40 Ford. See post #17 below. https://www.ford-trucks.com/forums/843647-1950-255ci-flathead-merc-in-a-1952-f1-2.html
File the little wide spline in the pitman to look like all the other splines. Then you will have an infinite adjustment. Use a small triangle shaped file. But this still might not let you clear the pan.
Thanks for the all the responses, we will try a file and will probably have the bend the radius rod. Best site ever!
Moving the pitman arm solves nothing. Modify the truck pan with a hammer or move the sump back by cutting & welding. The best fix is a '49 or '50 Mercury pan.
