Projects 36 ford x- member
Discussion in 'The Hokey Ass Message Board' started by roger didonato, Oct 31, 2016.
  1. roger didonato
    roger didonato
    Still need info on installing tubular x-member in my 36 ute thanx
  2. That's a pretty wide open question. Do you mean like how to instructions or why you should or shouldn't, who's to use?
    The Wizzard
  3. roger didonato
    roger didonato
    Thanx for the reply.I guess pretty much all those questions or would I be better off just using the center mount kit as I want to use a turbo 350
  4. wbrw32
    wbrw32
    This is your answer
  5. RainierHooker
    RainierHooker
    from Tacoma, WA
    Yup. The stock X-members will be stronger than you could ever need, unless they are badly corroded, have all the proper holes and mounts in them, are the right size, and already in your frame...
  6. Rainier****** is right on. Unless your starting with S**** Iron for a stock X member I can't think of any good reason to cut it out and try to piece together a tube style. In fact I have had 1/8" folded up to repair and replace several stock X members. I could have just as easily walked over and bent my own tubelure style units. To me it's just the wrong direction for a 36 ute.
    The Wizzard
  7. roger didonato
    roger didonato
    Thanx for your reply guess Ill go with the stock xmember
  8. roger didonato
    roger didonato
    Thanx to you & Rain****** Saves me a lot of work
  9. brigrat
    brigrat
    from Wa.St.
    I believe there's a Ch***is Eng. kit in the cl***ifieds for a '36-'40 w/350..................................................
  10. VCS
    VCS
    I have the bare plate available if your interested
