Technical 36 Ford.
Discussion in 'Traditional Customs' started by jmponcho, Dec 4, 2020.
  1. jmponcho
    jmponcho
    Any of you guys have any pics of inside the quarter panels of a 36 Ford 5 window? I have one that someone started to put a floor, lower quarter panels in. I need to fab the pieces but both side were cut out. Any pics would greatly help!
  2. 363wcpe
    363wcpe
  3. reagen
    reagen
    Try looking on the ford barn site
  4. jmponcho
    jmponcho
    reagen and KiWinUS like this.
  5. Sherry.Oliver
    Sherry.Oliver
    No, but want to bump the thread to the top
    jmponcho likes this.
  6. reagen
    reagen
    Hope these help you out Jmponcho
  7. jmponcho
    jmponcho
    Thank you very much!
  8. Nailhead Jason
    Nailhead Jason
    The sub rails obviously extend further back, but they spot weld face to face with the stepped bead on the lower portion of the quarter leaving a flange at the bottom. Make sure to put a drain hole at the front and rear of the trough that is created when extending the rocker panel/subrail area for drainage. Once the rocker sub rail is extended to the quarter and welded in, there is a 90* piece of Sheetmetal that extends from the B pillar to the seat riser on a sedan or back to the wheel well on a coupe that is there to support an interior panel. If you don't put that there there is nothing to support the panel at the floor edge. This is the rocker and floor replacement on my 39 but the 35 though 40 bodys are very similar in this area if not exactly the same. Pictures arnt the greatest but you get the idea.
    brigrat and lothiandon1940 like this.
  9. ronzmtrwrx
    ronzmtrwrx
    Here’s a couple of shots E294FC98-597D-4670-802E-695265FE0438.jpeg D3675DD1-B733-4160-93DF-3E1AFA3041F0.jpeg of my 39 drivers side quarter looking rearward. Not sure if they’re the same as a 36, though.
