Isn't their someone making the oval axle tube brackets to mount 36 radius rods? Info would be most appreciated.Thanks
If you have a drawing compass and way of cutting 3/8 steel, why not try fabbing your own? I'm no master fabricator and I was able to make mine. Justin
Some Hambers like Lowsquire also suggest to lower the 2 mounting holes to get the car to sit lower. Also, lots of donor rear ends have larger tubes, so the bolt holes can't fit higher like on a Ford banjo style tube. The rear of the 35/36 yoke won't fit up that high. I made my own like they said and it seems to be a good idea. Most I have seen on non-original rear ends are C shaped and just weld to the lower underside half of the axle tube.
Full Circle And Half circle Both in stock and ready to go. You can buy them directly from my website.
Well crap... If you guys have been having issues with my website, you're right. e-Commerce is the shop plug-in I use on my website. Been stable for years, until now. They have not been doing the maintenance needed and they broke the shipping tables. Working on a solution and should have things back up and running by this afternoon with another plug-in. In the mean time, give me a call, free: 866-553-8996 Steve
Webstore is back up and running for the most part. Payment is through PayPal for right now. Working on direct credit card transactions this weeks.
