Projects '36 Roof Insert
Discussion in 'Traditional Hot Rods' started by DAVID WEBB, Nov 9, 2024.
  1. DAVID WEBB
    DAVID WEBB
    from Florida
    I have a '36 Ford Sedan that has a "vinyl" roof insert that looks different from the new ones advertised. It is almost at the same level as the metal part of the roof with a hard rubber edge. Has anyone seen one of these? Seems like the new vinyl inserts sit higher than this. Somebody sealed this up with a silver coat of something. Nothing like having to re paint just to have a new cover. Any info appreciated IMG_2068 (1).jpg IMG_2074.jpg IMG_2074.jpg
  2. krylon32
    krylon32
    from Nebraska
    Looks a little bulky. I've done several with metal inserts screwed to the wood and covered with Hartz cloth. Smooth and flush with the top.
    lothiandon1940 and Tow Truck Tom like this.
  3. Rusty O'Toole
    Rusty O'Toole
    As originally built the insert was flush with the roof and had a narrow bead or molding around the edge. Vintage Ford spe******ts sell a kit of materials to replace this insert.
  4. nochop
    nochop
    from norcal
    Rv roof coating?
    lothiandon1940 likes this.
  5. snoc653
    snoc653
    from Iowa
    That is what it looks like to me. Should be able to remove the silver sealer without damaging the paint if you are careful. Once you remove the old top try different solvents on the top or chunks that flake off and see what works best.
  6. DAVID WEBB
    DAVID WEBB
    from Florida
    You lost me with the screw inserts. It sounds like a good plan, but I wouldn't know where to start. I have to look up Hartz cloth---is it waterproof?
  7. DAVID WEBB
    DAVID WEBB
    from Florida
    That's what this looks like---must be original. I will look up Vintage Ford. Thanks
  8. DAVID WEBB
    DAVID WEBB
    from Florida
    It could be RV coating. It's tough. I am going to tape off the area where the overlap sealer is on the painted roof, so if I have to repaint, it won't be so much.
  9. DAVID WEBB
    DAVID WEBB
    from Florida
    I found the Hartz Cloth. Convertible top cloth with a cotton backing---perfect!
  10. DAVID WEBB
    DAVID WEBB
    from Florida
    I couldn't find Vintage Ford Spec. Any ideas? I am sure that I will need the outside ring and other little parts once I get it off, Thanks
  11. snoc653
    snoc653
    from Iowa
    If you plan to repaint the area where the sealer is on the metal regardless. Tape it off like you plan and then try a citrus paint remover and aircraft paint stripper. Both can take layers off if applied and managed properly. I personally prefer the aircraft paint remover. I have removed paint from cars with it leaving the original paint intact. Could save you a lot of work.
    DAVID WEBB likes this.
  12. Rusty O'Toole
    Rusty O'Toole
    You might find this of interest
    Irish Mike and lothiandon1940 like this.
  13. DAVID WEBB
    DAVID WEBB
    from Florida
    Thanks! Everything helps
