Projects 36-taildragger.....Made in Sweden
Discussion in 'Traditional Customs' started by Kenneth31coupe, Mar 17, 2013.
  1. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Continued with the p***engerside a-pillar today and had no expectations at all after what the other side looked like just go on and get it fixed.
    Cut out the bad part and was really surpriced of what I found. Under the first layer the inner post was really nice. Only some surface rust so I just brushed it off and painted it with zink primer
    Made a new piece to fill the cut out part and here it´s done.Wish it allways would have been this easy
  2. kippers 34
    kippers 34
    Looks great Kenneth. You got a whole lot more done than I did last week.
  3. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks Kipp.Maybe more than what you have done lately but not much of progress any way. Today I mounted the doors in to see how they fitted after all work I´ve done on the pillars.Not that bad after all,driver side needs a little adjusting to fit the body line and reveals but p***enger side takes a lot more work.Will adjust them both so they fit properly with the reveal and body line before I start cutting in them for rust repair.Think it´s easier to do that now instead of after the repair.
  4. brian55lvr
    brian55lvr
    from ma
    yes--easier to line now---then patch/file and tweak
  5. kippers 34
    kippers 34
    Nice to see the doors back on Kenneth. Once the repairs are done then the fun can begin.
  6. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Nothing much happens in the garage these days.Thousands of other things to do but managed to get some time left over this weekend.Got the doors aligned but couldn´t start repairing them since I had run out of sheet metal.
    Started on this instead. It´s the hole for the trunk and it got som rotten parts there too. Braked a piece of sheet metal and shrinked it a little to get the right radius and then popped some holes in it for spot welding
    The catwalk was not perfect when I started and it requiered some heatshrinking and hammer n dolly after welding maybe would have been easier to replace it but I like to keep as much Henry metal as possible so if it´s not rotten I try to straiten it.
    After a couple of hours of shrinking and hammering I think it´s good enough.
  7. heyitsnate
    heyitsnate
    looks good! what all did you have to do to align your doors?
  8. 53chevtrev
    53chevtrev
    from Langley BC
    Awesome work dude! Love this build so much.
  9. Finnrodder
    Finnrodder
    from Finland
    Yeah,still looks good!
  10. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks Nate. Don´t know if I was lucky but when all screws were tightend the doors fit allmost perfect in front.Only had to warm and bend the lower hinge on driversides door slightly to make it parallell whith the cowl.In back there where not more than about 1/8" to 3/16" the door needed to rise for alignment so I did it simple and just lifted the door by hand to make it fit. Everything moves smothly and no bending in the hinges.Feared this would be a nightmare at first:)
    Thanks Trev. Much appreciated
  11. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks Finnrodder
  12. neilswheels
    neilswheels
    from England
    Great work, I need a Pullmax!!
  13. kippers 34
    kippers 34
    Catwalk came out nice Kenneth. Getting closer.
  14. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks
    Thanks Kipp.Have started on the doors and when they´re done I think the kustomizing part can begin so yes definetly getting closer:)
  15. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Have started on the doors.Have to replace both outer and inner bottom parts. Before I start cut them appart I will make some new panels.Cut out a sheet and shrinked it a little along upper and lower edges to make it curve.Then I´d run it in the pullmax with doming dies for a smoth radius.
    The bottom edge was trimed with a bodyfile to get a smooth edge for the bead.
    To make the bead I had to first make some dieholders and some dies for the pullmax. Made the dieholders so that I can bolt the dies in it. In that way I can make other dies and just switch around.
    Here is driver door done only have to brake the edges to fold around the door inner piece but will wait to do tha untill its time to install it.Have to make the inner part first.
  16. K13
    K13
    Nice work the pullmax must come in handy for those types of things.
  17. ESGEE
    ESGEE
    from Sweden
    Fresh work as allways...
  18. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks. I would say it´s priceless right now.
    Thanks.
  19. lowcoe
    lowcoe
    Pulllmax envy. Is that a thing? If it is, I got it!
    Great work!
  20. CoolHand
    CoolHand
    Alliance Vendor
    It's a thing.
    I've got it too. ;)
  21. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Sorry! Wasn´t my intention to make you feel like this :eek:
    Got the door bottoms made yesterday. Started with a sheet that I braked like an L
    A trip in the stretcher to make it curve
    Then a trip in the pullmax
    Made a tool like this to make the dimples
    Laid the panel over that die and then I have this one to make the dimple.Hit it with a "plastic" hammer and there´s a dimple
    Then I simply bend the flange with a wrench.I think it´s the easiest way with such small flanges.
    Here´s the driver side done.
    chryslerfan55 and schoum like this.
  22. telekenfun
    telekenfun
    Kenneth, your work never ceases to amaze me! Great stuff! Best Regards and Good Luck with all your endeavors. KB aka telekenfun
  23. lowcoe
    lowcoe
    Better watch out , The guys over at EMS are gonna be out for blood now that you took the mystery out of making a Ford door bottom! Thanks for showing us how step by step!!
  24. kippers 34
    kippers 34
    Beautiful Kenneth!
  25. longgoner
    longgoner
    from western ny
    I alway's look forward to seeing your methods and progress.
    Well deserved compliments to your skills and perseverance, Kenneth.
  26. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks KB
  27. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Time to repair the doors.Started with the outer panel and tacked it in place keeping the old bottom as reference to keep the shape on the door.
    When the outer panel was fitting and tacked I cut out the bottom and tacked in the new one.
    When those panels where properly fitted I cut out the whole inner panel and parted the door in two.Now I have acces to the inside of the outer skin so I can hammer n dolly after welding
    Also makes access of the inside of the hinges and it sure was necessary since the lower hinge had losen from the stiffening bracket.Probably thats why I had to heatbend that for the door to fit.Now I can make some proper stiffening here.Not sure yet how to do it but I will figuere out something
  28. kippers 34
    kippers 34
    Dam you have been busy Kenneth. Looking extreamly good. I feel like a slacker lately.
  29. brian55lvr
    brian55lvr
    from ma
    nice work ,door bottom looks great
  30. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Thanks Kipp.When speed is up better keep going.
    Thanks.
