365hp 327 sbc Cam Question ??????
Discussion in 'The Hokey Ass Message Board' started by ocfab, May 9, 2008.
  1. ocfab
    ocfab
    Do any of you guys have the stock cam specs for the 365hp solid lift cam?
    Thanks,
    OC.Fab
  2. repoguy
    repoguy
    Found this:
    Basic operating RPM range: 2,800-6,800 RPM
    Camshaft style: mechanical flat tappet
    Cross reference: GM #3849346
    Duration (@ 050 inch lift): 254 int. / 254 exh.
    Duration (advertised): 346 int. / 346 exh.
    Lifters: Solid
    Lobe separation (degrees): 114
    Valve lash: .024 int. / .026 exh.
    Valve lift (w/factory rocker ratio): .485 int. / .485 exh.
    1Nimrod likes this.
  3. Shane T.
    Shane T.
    I like the off road design 2 z-28 cam better FWIW.
  4. tommy
    tommy
    We always referred to the 327-365 HP cam as the 30-30 cam because that was the valve lash. This is from memory but I think I'm right.
  5. Shaggy
    Shaggy
    from Sultan, WA
    The specs are 30-30's
  6. ocfab
    ocfab
    Thank You !!!! God i love the HAMB.....
  7. lakes modified
    lakes modified
    Been there and had one of them & loved it. Would turn over 10 grand at times, but ate plugs like crazy.
  8. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Had one in a 62 Impala back in the 70's. Wicked cam. Back then I didnt mind adjusting the lifters once a week. I always heard it called a 3030 Duntov so I supposed Arkus Duntov designed it. Sounds good anyway.
    1Nimrod likes this.
  9. PumpGasRatVette
    PumpGasRatVette
    A good cam to show you how some specs can really make HP! Like 'em a lot.
  10. Wow- hard to believe that's a factory spec cam-- that thing is a monster!
  11. turdytoo
    turdytoo
    Between 30-30 cams and Corvette valve covers, there were way more Corvette claimed to be motors in cars than GM ever built.
  12. All I can say is they sound magical:D
    1Nimrod likes this.
  13. pitman
    pitman
    The PN:3863152 hydraulic cam was rated at 350hp, and it came on at 3K rpm...had just enough lope at idle to suggest something was up. I never had to set another lifter after that.
    Here's a good spec site for most of the factory cams.
    http://www.geocities.com/MotorCity/Downs/3000/cmspec.html
