Hot Rods 368 Y..take the plunge?
Discussion in 'The Hokey Ass Message Board' started by 68shortwide, Nov 4, 2019.
  1. drtrcrV-8
    drtrcrV-8
    Suggest a good tune-up/rejuvenation with FULL maintenance of the brake system and all filters & fluids(wheel bearings, power steering, transmission, rear end, as well as all zerk points) &, unless you know for sure they are less than 3yrs old, wiper blades, ALL belts & hoses, ESPECIALLY the heater hoses to the under seat heaters!!(Most people don't know about them, let alone think about changing the hoses to them, & Mr. Murphy just LOVES to say "Hello" at the worst possible time!!) Once you do the service, drive her : you will find that, especially for her time period, she will be surprisingly "spry", & certainly able to keep up in traffic!
    warhorseracing likes this.
  2. TBone69
    TBone69
    from NJ
    Brake system needs a full rebuild, wheel cylinders leaking, treadle-vac is seized, looking to upgrade to a modern dual reservoir master and booster. I'm currently working on freeing up the front parking brake cable so at least I have parking brake. I'm new to these 50's FoMoCo vehicles, am I not supposed to run the engine while park iis engaged, heard something about blowing out the trans seals if I do.
    Good call on the under seat heaters, took me a while to figure out what the heck that box with hoses was. I'll probably just loop if off for now to get her yard driving.
  3. drtrcrV-8
    drtrcrV-8
    I haven't been "involved" in quite a while, but when I was, I found Lincoln & Continental Owners Club(LCOC) & The Road Race Register to be sources of information & sometimes parts. RockAuto Parts has replacement wheel cylinders(new replacements are easier than rebuilding the originals), as well as some other parts. Suggest purchasing a Motor's Manual('55 through '60 will have your '55 Lincoln), & keep an eye out for owner's manuals & service bulletins for your year both online & at swapmeets... Fortunately you are close enough to the Hershey Swapmeet to be able to take advantage of the "Mother Lode" for parts, literature, & information... &, of course, the HAMB!! LOL! Also check over on the FORD BARN, as these are a Ford product, & do show up on the site from time to time...
  4. TBone69
    TBone69
    from NJ
    Well looks like the 341 is going to need a full rebuild, found stuck valves, bent push rod and bore scope shows all cylinders equally stuck. Looks like she was a oil burner for a long time.
    IMG_4269.jpg IMG_4267.jpg Image_2024-10-20 12_17_23_786.png Image_2024-10-20 12_42_39_819.png Image_2024-10-20 12_42_50_825.png
    With pistons alone almost $100 a piece I'm tempted to do an engine swap, 390, 460 ?
    Anyone know of a piston source other than Egge?
  5. d2_willys
    d2_willys
    from Kansas
    I will be swapping in a 368 into my 57 F100, and it will be coupled to a 53-54 Lincoln dual range hydramatic. Plenty of room and will use the ram horn manifolds. I say: GOPHER IT!
