Technical 37-38 flathead v8 21 stud
Discussion in 'The Hokey Ass Message Board' started by RMR&C, Aug 15, 2020.
  1. RMR&C
    RMR&C
    from NW Montana
    Is there any interest in these engines? Worth saving?
    I have a couple, one fairly complete I need to get rid of. Hate to scrap them..... 0815201031a.jpg 0815201031.jpg
    KiWinUS and fiftiescat like this.
  2. studebakerjoe
    studebakerjoe
    I'm sure someone will want them. If you weren't so far away I'd take them. Isn't always the way.
    RMR&C likes this.
  3. flatjack
    flatjack
    1937 blocks
    RMR&C likes this.
  4. There should be a market for it over on Fordbarn. Ford actually made block-off plates to cover the water pump holes in the front of the block. They frequently show up on EBAY. Once the block-off plates are installed all of the bolt-ons from 1932 through 1936 will go right on. You end with an engine with insert bearings (instead of babbit) that looks like a correct engine for a 1932 through 1936 Ford to all but an expert that knows to look for.
    Charlie Stephens
    RMR&C likes this.
  5. RMR&C
    RMR&C
    from NW Montana
    Thanks for the info.
    The one block has the block off plates. I plan to keep those.
